Adrian Smith 1 Posted July 15, 2011 Share Posted July 15, 2011 I am getting fussy in my old age but on my bigger models (35cc and above) where I use a pull-pull arrangement on the elevator as well as the rudder, I want be sure of the tension is the wires is uniform. Is there anything on the market at a reasonable price that would perform the function of industrial wire tension meters but on thin wire for models? I know I may be asking the impossible as I don't want anything that acts like a "sledgehammer on a nut." Failing that I will use my usual method of pinging the wires like a dodgy guitarist! Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted July 15, 2011 Share Posted July 15, 2011 Other than sticking to the "ping" method (which is the same as I do) you could get a pitch meter for guitar strings! Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted July 16, 2011 Author Share Posted July 16, 2011 Yes Doug I might research that. I must admit my question was more of a whim as it's not essential, I just thought there may be an easy way of measuring the tension. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 16, 2011 Share Posted July 16, 2011 I think that pull pull systems can often be overtensioned - most people who use these a lot suggest that its NOT necessary to have them "pinging" tight. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted July 16, 2011 Share Posted July 16, 2011 I'm definitely a "plonk" not a "plink" man. BEB Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted July 16, 2011 Author Share Posted July 16, 2011 Tim, I must admit I don't tension the wire too tight but I am trying to find that happy medium. Also I find it a bit disconcerting when running up the engine at full chat on the ground that both the rudder and elevator flap about a bit. However, thus far it doesn't seem to affect the flight performance. Quote Link to comment Share on other sites More sharing options...
