crispin church Posted July 30, 2011 Share Posted July 30, 2011 on a gws c130 herk change to brushless set up but can not get all 4 motors running right got one that stutters and then runs ok for a while then stops others stop on low thro when the inside one still running i got 4 x emax 1806/25 4 x esc 25 amps on one 3c lipo Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 30, 2011 Share Posted July 30, 2011 Have you gone through the procedure to calibrate the ESCs against Tx stick movement ? Quote Link to comment Share on other sites More sharing options...
crispin church Posted July 30, 2011 Author Share Posted July 30, 2011 no i dont know about that? Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 30, 2011 Share Posted July 30, 2011 If the ESCs are Hobby Wing or one of the re-badged versions there should be instructions under the heading "Throttle Range Setting". Switch Tx on move throttle to high > connect battery to ESC wait about 2 secs > "beep - beep" tone from ESC means high point confirmed > move throttle to low - 3 beeps for 3 cell lipo > finally one long beep confirms low point of throttle. I think to avoid confusion you will need to do this for each ESC individually. The settings are stored when the battery is disconnected (otherwise you would need to repeat the process every flight) but if you use a different Tx the procedure may need repeating. Quote Link to comment Share on other sites More sharing options...
crispin church Posted July 30, 2011 Author Share Posted July 30, 2011 ok thanks never knew that i got them all wired in one on rx wire so hope all in one will be ok many thanks Crispin Quote Link to comment Share on other sites More sharing options...
