Tornado V2 4A ESC Brake set-up
Mark
I'm trying to set the brake ON on this ESC without any success. I can enter the programming mode OK and hear the sequence of ever increasing number of beeps but whichever one I try to change by moving the throttle to low it doesn,t affect the brake - or indeed anu other parameter although it does exit the programming mode at low throttle. There must be some other action on the throttle to actually change a parameter.
Anyone got any instructions or experience with this ESC?
Mark
  • 5 years later...
Denis, Thanks for the quick reply. Mine doesn't seem to work like this. When you enter programming mode you just get a series of ever increasing numbers of beeps. I've tried closing the throttle after the pair of beeps but it doesn't change anything. Trim is set to fully low. The throttle works in the correct sense so is there any reason to reverse it. Mark
