Phil 9 Posted September 7, 2011 Share Posted September 7, 2011 I am putting together a ultra stick 40 with 4 servos in the wing (quad flaps) thats alot of connectors. what would be the best sindle connector I could use to make field set up easy Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted September 7, 2011 Share Posted September 7, 2011 multiplex green connectors Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted September 7, 2011 Share Posted September 7, 2011 Are the servos working in pairs (or even all together), or do they each run off a separate receiver channel? If they're in pairs, you can reduce the number of wires down to four, and then use a Micro Deans 4-pin plug (second row on this page), as follows:- Connect all the red wires together, to pin 1;Connect all the black wires together, to pin 2;Connect the white wires from one pair of servos together, to pin 3;Connect the white wires from the other pair together, to pin 4. Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted September 7, 2011 Author Share Posted September 7, 2011 Allan each servo must have its own channel I thought about multiplex connectors as I already have some but I still would need two and I hoped to just use one connector for the lotEdited By Phil B on 07/09/2011 20:47:58 Quote Link to comment Share on other sites More sharing options...
Andy Green Posted September 7, 2011 Share Posted September 7, 2011 I'm a huge fan of Ashlok connectors My Star Glider 4 servo wing connector Andy Edited By Andy Green on 07/09/2011 21:04:42 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 7, 2011 Share Posted September 7, 2011 Ive used em for years, and another from me.I think the UK distributor is winding down though, so be quick, or you'll end up sourcing them from the US Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 8, 2011 Share Posted September 8, 2011 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted September 8, 2011 Share Posted September 8, 2011 Posted by Phil B on 07/09/2011 20:45:54:Allan each servo must have its own channel I thought about multiplex connectors as I already have some but I still would need two and I hoped to just use one connector for the lotEdited By Phil B on 07/09/2011 20:47:58 OK, so I would probably go for two Micro Deans 4-pin instead of two larger Multiplex. You can get them in red or black, so no confusing the two plugs. One would be for each of the four signal wires, and the other could take the red/black wires paired up. Quote Link to comment Share on other sites More sharing options...
