Steve Hargreaves - Moderator Posted December 14, 2012 Share Posted December 14, 2012 Ah...so theres a brace in there already Adrian.....OK that looks fine....I was a bit worried that you were relying on a butt joint between the wing panel & the centre section & this wouldn't have been enough IMHO. Yep I think you will have quite adequate power in that set up for even a moderately overweight Pix 'E'....maybe call it a "Slightly Flab 'E'"... You can always increase the prop size up to 9" for a bit of extra oomph after all.....the motor is good for around 120watts so theres plenty of power available to fly this model..... Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 14, 2012 Author Share Posted December 14, 2012 morning Steve when i first started building it i was lookng and thinking how can i get one in there with the centre section built .. as i made the model on the plane and had glued the centre ribs in place took a little thinking and some simple cuts but got it there in the end needed it a little stronger as didn't trust the original fitting for some reason.. its a little better now i hope with the brace in and if i add the rod too should keep it solid good to hear about the set up being ok .. i don't want it flying fast just a plod about model.. something for those nice calm relaxing flying days .. so if i stick with the slow fly prop and the setup from before will be perfect.. good good .. 120w thats some little motor not that i want anything like that 70 sounds good to me ?? thanks again for your help Adrian Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted December 14, 2012 Share Posted December 14, 2012 You control the maximum power output Adrian.....just change the prop..... If it had been me I think I would have used a 1/16" ply dihedral brace attached to the front of the spar & fitted to a "spar" across the centre section but the method you have used looks fine....the trick is to try & consider all the forces acting on the part & build the structure to withstand these forces. As the saying goes "Anyone can build a bridge that will stand up but it takes an engineer to build a bridge that will just stand up" We aeromodellers tend to be "experimental" engineers much like Isambard Kingdom Brunel who, on being told that a bridge he had designed & recently completed had, in fact, fallen down replied "Sir, I thank you for telling me for I had planned to build three more!!" Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 14, 2012 Share Posted December 14, 2012 This thread is fast becoming a masterclass in itself! tim Quote Link to comment Share on other sites More sharing options...
ian ludwell Posted December 14, 2012 Share Posted December 14, 2012 Good evening all, Started cutting out the parts this morning. So much better with the laser cut parts. Both wings well on the way,fuselage sides same. Feet cold,fingers cold,but enjoyed it all the same. Didn't use the undercarriage style last time but need to rake it more forward this time,used to tip over on landing before. Regards Ian Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 15, 2012 Author Share Posted December 15, 2012 thats what i like Tim with threads like these its a constant learning curve, i think when you have good people like your self and Steve with the know how and the way that every modeller helps each other theres the odd one who goes competitive but all in all we help each other.. ... wish this world was more like this hobby all i can say.. thank you steve for your input there Still getting to grips on the prop front .. working with sizing and slow fly so on so on.. think i still have some learning .. like the comment about the bridge you have some very wise words there. ... Ian Sounds like you have been a busy bee today .. its great working on this model from the CNC kits make life simple.. fast and effective.. will be waiting for the pictures of the build process The landing gear is a little thing to play around with i find on the model.. guess its try and test till you get the best.. All the best to you all Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 22, 2012 Author Share Posted December 22, 2012 Well been covering some of the wing today.. it looks ok ... but not happy with it dont' know why but think its going to be a recover job..dont like the tail end.. the main wings i like the look of simple clear covering with red and silver tip lines but as for the tail well that's another thing.. was going with red/blue on my original design. so i covered the tail and now i don't like it at all .. how simple is it to pull covering off with out making the balsa get shredded or snapped ???? may have to make a new one not that i want to.. fingers crossed it will come away and look ok. anyone got simple ideas on taking the covering off???? regards Adrian Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 26, 2012 Author Share Posted December 26, 2012 latest picture So what do you think so far just the tail to finish, add the push rods, and electrics to finish then she ready to fly .. oh and the front glazing but it looks ok for now Quote Link to comment Share on other sites More sharing options...
ian ludwell Posted December 26, 2012 Share Posted December 26, 2012 Hello Adrian, Hope christmas was good for you The Pix-e looks very nice,i like the look of the extra wing( ties or struts) dependant on tension or compression. Where did the idea for inserting them come from. Are they structural or cosmetic? Regards ..Ian Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 26, 2012 Author Share Posted December 26, 2012 thank you Ian Merry Christmas to you .. Christmas was pretty good thank you .. just a relax day with partner and her family.. hope that your day was good. thank you for your comments / question.. those struts are there for structural rigidity I wasn't happy with the strength of the wing as it flexes a little when not covered so wasn't taking any chances on this happening when covered .. its made this a pretty solid model now.. (where the idea come from ) Well I see a model with them a few years back just as a little strength for the first 3 ribs the person said that it stops twisting of the wings and helps take the pressure off the root rib ... don't take my word for it. as i cant say its proven till i have tried it. I now like the look of it to now I have clear covering on the wings regards Adrian Quote Link to comment Share on other sites More sharing options...
ian ludwell Posted December 26, 2012 Share Posted December 26, 2012 Hello to everyone, Hope you have had agood christmas. Back to building,fuz completed from formers to rear. Motor mount located onto F1 and held in place with captive nuts to the rear,2 pieces from front cowl cut out to clear motor case and glued together. Will glue F1 into place this aft. Looking at earlier notes i think i shall use the 2812 motor,9x4.7 slow fly prop and 2s 1300 mAh li-po set up. Will fit the same struts into the wings as you have Adrian,as you suggest to try to prevent wing warp. I had a couple of occasions during the year where the wings had warped and caused quite a stir as i flew it and not checked them. So will fit my sruts from spar to T/E,like the idea of yours Adrian. Going to try and make the U/C as per the plan. Regards Ian Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 26, 2012 Share Posted December 26, 2012 Adrian, The PIx-E looks great, especially the colours you've chosen! tim Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 26, 2012 Author Share Posted December 26, 2012 thanks Tim wasnt sure the colours would go but they fell out the cupboard the other day together out of the 20 so rolls i have and they just blended .... dont know about the design of the colours together but its not my strong point Regards Adrian Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 26, 2012 Author Share Posted December 26, 2012 Good evening Ian like the set up i think i have links to them on page 3 of this post ... prices work out around the £25 delivered .. i know I'm happy with them. sounds like you have been doing well then from what you have written when the pics starting to pop up keep up the great work the way your going you will have this sorted in the next few days not good on having wing warp i would like that i did notice when i was coving the first model that you get some depending on heat of the covering.. so that's also a reason that i have added these into this one.. hope that what you have found on this page has been of some help.. the people that have been helping me i couldn't ask for more.. they have been a big help well i look forward to seeing some pictures of your build progress Regards Adrian. Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 27, 2012 Author Share Posted December 27, 2012 well i couldn't sleep so have made a new tail end for the Pix-E as wasn't happy with the old one, So now its setting and looking a little better than before. later today i will cover it and then i think it will be ready for fitting the push rods .. looking forward to the fitting out of the electrics and seeing everything come together, have to say I'm much happier with this than my first one that i built. more pictures to follow this afternoon.. bed calling as its now 3:10 am and the old eyes dropping Regards Adrian Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted December 27, 2012 Share Posted December 27, 2012 Looking good Adrian..... Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 27, 2012 Author Share Posted December 27, 2012 thanks Steve been a productive day shaping the tail feathers and covering its now nearly finished .. going to make the landing gear this evening.. looking forward to seeing it sitting like a proper plane.. not on it belly. just ordered the electrics, and the wheels so they should be here by 3/4 jan be happy then regards Adrian Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 28, 2012 Author Share Posted December 28, 2012 well test fitted the tail last night and fitted a windscreen bar then this morning fitted the windscreen so taken some more pictures let me know what you think .. I don't think she looks to bad but like other poeple's judgement also plucked up the courage to glide test this morning so with a little push away she glided about 15ft levelled out with a perfect belly landing.. very happy indeed Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted December 28, 2012 Share Posted December 28, 2012 She looks great.......will you make one for me......? Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 28, 2012 Author Share Posted December 28, 2012 thank you Steve .. and to your request anytime mate forgot to add I weighed her in today with out wheels and elec's 185g think in oz that about 6.5oz not to bad fully covered was thinking she would be a litlle more 7-8 oz but seems to be on a good diet Regards Adrian Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted December 28, 2012 Share Posted December 28, 2012 She looks superb Adrian! You've come a long way in a very short time - there's not many modellers who would be brave enough to show their building skills by choosing a clear covering film! tim Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 29, 2012 Author Share Posted December 29, 2012 Thank you Tim nice to get a compliment like that from someone I look up to in the Model building world, the clear covering really does this model justice, I think your design work needs to stand out the only thing that I didn't think about was the fact that I had written the numbers and lettering on the ribs and wing parts.. so they can be seen.. .. I just hope that the craft work I have done is up to the scratch of being shown.. also i have been watching your builds and a few others. and been trying to learn some new techniques that I have put into this model that I didn't know before making the original.. Thanks again Tim Regards Adrian Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 30, 2012 Author Share Posted December 30, 2012 got the landing gear added on today couldn't wait till the delivery arrived so went out and got some new wheels from a local shop yesterday.. so now she sitting pretty good on foamies Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted January 8, 2013 Author Share Posted January 8, 2013 push rods fitted now and working second view working on a second wing set for this dont know if it will work the way i have done it.. its just test dont know if the size and placing of the aileron will be ok or not its about 8 inches long Quote Link to comment Share on other sites More sharing options...
ian ludwell Posted January 8, 2013 Share Posted January 8, 2013 Hello Adrian, All looking very nice. Are the new wings with Ailerons for the pix-e? I assume you are keeping the wings flat,ie no dihedral. good luck. Regards ..Ian Quote Link to comment Share on other sites More sharing options...
