ericrw Posted January 9, 2012 Share Posted January 9, 2012 Is it fairly straight forward to fit a Hobbywing UBEC, to my existing Hobbywing 60amp ESC. And if so any advice on how to do it would be appreciated !! Quote Link to comment Share on other sites More sharing options...
Pete B Posted January 9, 2012 Share Posted January 9, 2012 Solder the red and black pair of wires to the red and black cables on the ESC side of the connecting plug, Eric. You can either do this at the plug terminals or anywhere suitable along the cable. You just strip the insulation, lay the wire alongside and solder them on. A bit of heatshrink to cover the joint, remove the red-wired pin from the 3pin Rx connection (rather than cut it as you can re-use again if you wish) and the job's done. The UBEC will become live when you plug in the battery pack. Pete Quote Link to comment Share on other sites More sharing options...
ericrw Posted January 9, 2012 Author Share Posted January 9, 2012 Thanks Pete, I seem to be getting to know you !! I'm collecting various items in preparation for my Beaver. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted January 9, 2012 Share Posted January 9, 2012 That would certainly do it....I usually solder the input wires from the BEC into the battery connectors of the ESC & then cover the connectors with heatshrink....saves stripping the insulation from the ESC wires. Do make sure you make a good job of the solder joint....if the BEC connection fails your RC model becomes a free flight model....... Quote Link to comment Share on other sites More sharing options...
Pete B Posted January 9, 2012 Share Posted January 9, 2012 That's my preferred connection point too, Steve, but with some connectors it can be quite difficult to juggle two wires, a connector and an iron to get a satisfactory joint, all at the same time!Pete Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted January 10, 2012 Share Posted January 10, 2012 True Pete, very true.....God obviously made a bit of a mistake when he only gave us two hands...... Quote Link to comment Share on other sites More sharing options...
ericrw Posted January 21, 2012 Author Share Posted January 21, 2012 I have now soldered the two wires from the UBEC to the ESC. Now I need to know which wire connects to the receiver. Is it the black & red from the UBEC or the B/R/W from the ESC ?? There is also a switch attached to the UBEC. The wires on the switch are not long enough to fit anywhere other than inside the Cowl; which would make it inaccessable, without removing the Cowl. Quote Link to comment Share on other sites More sharing options...
Ben B Posted January 21, 2012 Share Posted January 21, 2012 They both need to go to the receiver, the B/R/W one goes to the throttle channel, the Ubec one goes to a spare channel. Or if you're short on receiver slots you can combine them in a Y lead and put them both into the throttle channel. for what it's worth I prefer stripping a small bit off mid-way along the ESC power leads, wrapping the thinner Ubec lead around that in a spiral, soldering and then heat-shrinking... As said it's hard enough getting one cable into some connectors to solder without having two. Quote Link to comment Share on other sites More sharing options...
Pete B Posted January 21, 2012 Share Posted January 21, 2012 As Ben says, but now you have power from the UBEC, you do not need power from the ESC. Remove the middle (red) wire from the 3-pin plug (preferably by lifting the tiny tab and extracting the pin, rather than cutting the wire), insulate and tape the spare wire to the lead, and you now have just a negative (black) and signal (white) lead from the ESC. It's better to retain the pin and tape it onto the lead as you may want to use the ESC BEC at some time in the future. Pete Quote Link to comment Share on other sites More sharing options...
Ben B Posted January 21, 2012 Share Posted January 21, 2012 If it's the opto 60A then this is not necessary as it has no BEC and some people say it's not necessary even if it does have a BEC..... Quote Link to comment Share on other sites More sharing options...
