TonyS Posted January 21, 2012 Share Posted January 21, 2012 I've been flying a Multiplex Gemini with the tuning set and recently the thing sounds like it's going to shake itself to pieces as soon as I open the throttle. It's not too bad at very low revs. I've had the thing apart and checked the motor mounts so I don't think that's a problem. Someone suggested that maybe the motor shaft is bent so I thought I'd give changing that a go. Anyone ever had the need to do this? Is it easy / possible and does anyone know where I might be able to source a new shaft? Thanks Tony Quote Link to comment Share on other sites More sharing options...
Seamus O'Leprosy Posted January 21, 2012 Share Posted January 21, 2012 I know where to get spare shafts for various motorsand I am sure you could get one to fit the himax.I hate the mount system on the multiplex foamies, the one on myAcromaster has given no end of trouble with symptoms similar to yours. Unless the shaft has an obvious bend the only way to check is to take it out and roll it on a piece of glass or a mirror, and I don't think it is possible to get it truly straight with standard model room tools. Quote Link to comment Share on other sites More sharing options...
Pete B Posted January 21, 2012 Share Posted January 21, 2012 I'd email one of the stores that sell Multiplex gear, Tony - a good test of their after-sales service!Pete Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted January 22, 2012 Share Posted January 22, 2012 tonys.....i've seen one of my friends with a gemini..with the same symptoms-you are describing...and the cause-- the motor mount........i've seen/heard the same problem on an acromaster as well...double check the mount and prop bal...... ken anderson ne...1....... mount dept. Quote Link to comment Share on other sites More sharing options...
TonyS Posted January 22, 2012 Author Share Posted January 22, 2012 Thanks chaps. Lots of good suggestions. I'll go back to the mount first as it's the most obvious and easiest/cheapest solution. Seems odd that it just developed the symptom but then it's a beast of a motor for a plastic mount stuck into some polystyrene! Quote Link to comment Share on other sites More sharing options...
