Cookson Posted April 19, 2012 Share Posted April 19, 2012 A contact through my flying club has given me a Ripmax Dazzler, it was built by his father late '60s early '70s, it has never flown or even had an engine or servo's mounted in it. Generally looks to be in sound condition but has been stored near a window at some point and the yellow painted finish is faded across the wings which are foam veneer. I want to get this model in the air but 1st needs checking over & a re-paint. Any suggestions on what I should check apart from the obvious, what colour scheme, something from the era, what engine etc. I have a few tins of Flair spray paint, would this be ok to use. Quote Link to comment Share on other sites More sharing options...
Kelly Posted April 19, 2012 Share Posted April 19, 2012 Hi Cooko, I had two when I was a lad back in the 70's The smaller 30" wingspan and the larger 48". they did a 63" span version as well. Flew OK, had a bit of stick for not being a trad build from the balsa bashers . Check the wing join is good, bandage and araldite was the order of the day,or was it GF resin . Kelvin Quote Link to comment Share on other sites More sharing options...
Cookson Posted April 20, 2012 Author Share Posted April 20, 2012 Kelvin, Wow, like the pic, what year is that, which is you & what colour is the model (blue wings, yellow fus) ? This one I have is the 63" version, your comment "not being a trad build", I guess this was an early AARTF (almost almost ready to fly). Yes I can see the wing join, does look to be bandage & epoxy/resin joint & feels ok. Quote Link to comment Share on other sites More sharing options...
Kelly Posted May 1, 2012 Share Posted May 1, 2012 Hi, Sorry for the late reply. I am at the front, arm out touching the model. Yep colour scheme is correct, like to be different . If it had foam wings then it was considered to be ARTF , even though the fuselage was balsa sheet,strip and ply and had to be built up . Just to prove I can build from bits of wood and tissue a picture of me around the same time Veron Fokker DVIII - 48" wingspan- 2 channel R/C rudder/elevator - Webra diesel engine. Still produced by Ben Buckle. Happy days . Quote Link to comment Share on other sites More sharing options...
Cookson Posted June 8, 2012 Author Share Posted June 8, 2012 Think I might paint mine red wings & yellow fuselage. Wish I had some old pics of my early model flying years, couldn't afford R/C but had a great time with control line combat & team racing. Quote Link to comment Share on other sites More sharing options...
