christopher small Posted December 14, 2007 Share Posted December 14, 2007 I have just bought my first park flyer a GWS Slow Stick with a GWS 100 speed controller and a JP 7.2 volt 400 ma 2/3AA Nicad (JST)Can I charge this rather small battery pack on my Irvine Delta-Peak charger disscharger,and if so where can i get a small red 2 pin male plug to connect my charger to the battery. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 15, 2007 Share Posted December 15, 2007 Hi Chris Most model shops should be able to help or any electric flight specialist retailer. I don't know the charger but assuming it's not Li-Po-only then yes, it should be fine. I assume this is your first electric model and one thing to consider going forward as you accumulate batteries is standardising your battery plugs.I use 4mm gold banana plugs on all my packs just for a simple life Quote Link to comment Share on other sites More sharing options...
christopher small Posted December 15, 2007 Author Share Posted December 15, 2007 Hi DavidThanks for your help,next time I am in Maplins I shall get some gold banana plugs.should make things a little easier,just plug in the lead you need.This is my second electric model the first being an Early Bird electric glider where it was a complete kit.My charger only charges NiCads/NiMh,but in slow charge mode it can go down to 50 ma so should be ok for my 400 ma pack.I have 4 battery packs so I shall try one and see. Quote Link to comment Share on other sites More sharing options...
