Vassilis Papangelis Posted July 3, 2012 Share Posted July 3, 2012 What would the effect be on the plane when it's vertical fin isn't exactly vertical to the horizontal stabilizer? I have an acro wot that after a repair I did I noticed that the vertical fin has a slight angle away from the vertical thus not being exactly perpendicular to the horizontal stab. What effect would this have to its flying characteristics? Should I bother realigning it? Quote Link to comment Share on other sites More sharing options...
Trex700e Posted July 3, 2012 Share Posted July 3, 2012 Youll most probably notice it when you use the rudder. The plane wont just yaw but will slightly climb and decend i should imagine. Quote Link to comment Share on other sites More sharing options...
Vassilis Papangelis Posted July 4, 2012 Author Share Posted July 4, 2012 Thanks. Would not like that happening. Should better realign it. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 4, 2012 Share Posted July 4, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 4, 2012 Share Posted July 4, 2012 As said, if only a bit out of alignment you won't notice. It would have to be around30 degrees out before it would even start to act like an elevator. Quote Link to comment Share on other sites More sharing options...
Steve Houghton 1 Posted July 4, 2012 Share Posted July 4, 2012 I have an EPP glider which needed repairs. Afterwards the fin had a pronounced angle on it and the tailplane also had quite an angle on it. Now this isn't some slow, stoogy glider, it can wack along at a fair pace when it wants to but I can't say I've noticed any difference at all. Steve A470Soaring.blogspot.com Edited By Steve Houghton 1 on 04/07/2012 08:32:40 Quote Link to comment Share on other sites More sharing options...
