BrianB Posted July 8, 2012 Share Posted July 8, 2012 Having bought the mechanical set from Unitracts for the 72" Spitfire I was expecting them to be a virtually`drop in` fit but find that they are,in fact,longer than those shown on the plan and stand proud of the wing by quite a bit.I can lower them into the wing a liitle bit but the retract actuator then fouls the upper sheeting,also the outer edge of the wheel is very close to the outer wing rib.I have built for well over 30 years and I find this is one of the least enjoyable models I have ever built despite the laser cut parts which are pretty good.Quite a few errors on the plan and now this with supposedly `custom` retracts.Who got it wrong?The mag or Unitracts? Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted July 9, 2012 Share Posted July 9, 2012 Hi Brian, I fitted the mechanical set from Unitracts too, I had to have them shortened by Tony to get them to work right. I seem to recall it was by 10mm. But once the correct length they fitted a treat. The wheel has to be skinny, and the ribs eased to get them to fit. I fitted the strakes on the outside of the upperwing skin to help with rigidity. They didn't sit proud of the wing though?? One of the fuselage formers was the wrong shape, but everything else fitted okay. If you haven't seen my blog its here "Don't just stand there, get one up!" Any questions fire away Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted July 9, 2012 Share Posted July 9, 2012 Hi Brian, just shows how rubbish my memory is. The retracts did indeed sit proud. Page 14 of my blog explains how I got around the issue. The rails had to be slimmed down by 4.5mm Cheers Danny Quote Link to comment Share on other sites More sharing options...
