amberbike Posted January 23, 2008 Share Posted January 23, 2008 Hello again,i have a ef sabre heli running off the standard 650mah 8.4 nimh battery with standard reciever,gyro,esc & mixer & a 370 brushed motor, is it possible to run this with my twister 11.1v 800 mah li-po battery?,if not what would be a suitable size li-po to use with this set-up if i can use a li-po at all, & could i use the twister li-po charger with any li-po battery or does it have to be a battery specific charger,any advice would be most welcome. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 23, 2008 Share Posted January 23, 2008 Hi Amberbike ( unusual name ? ) -the closest and safest match in LiPo terms to your 8.4V nickel pack is a 2 cell LiPo, at nominal 7.4V3s ( 11.1v) would more than likely push too many amps into your motor and release the magic smoke. The twister charger is designed for 2 cell lipo packs only and will not charge a 3s.You MUST stop flying as soon as you notice any drop off in the motor speed, as allowing a lipo battery to discharge too far will probably kill it, for ever. Quote Link to comment Share on other sites More sharing options...
amberbike Posted January 23, 2008 Author Share Posted January 23, 2008 Hi timbo thanks for replying,(amber is my dog & i own a honda goldwing so my kids came up with nickname)sorry my typeing error forgot to type in (skylift)after twister.so does that mean the lipo charger for my 3 cell 11.1 volt 800 mah battery that came with my skylift is no good to charge a 2 cell lipo that i need?the charger is:input 11.5-12.5V DC output0.8A. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 24, 2008 Share Posted January 24, 2008 I have no idea, as I am unfamiliar with the charger for the skylift. Quote Link to comment Share on other sites More sharing options...
David Martin 2 Posted January 24, 2008 Share Posted January 24, 2008 Hi Amberbike, you may be interested in these....A mate of mine uses one of these lipo chargers from RCMDIRECT that has auto cut off and is very reasonable at £7 if bought with one of their packs. Normal price is £10.99, which is still good value I think. They run off a 12v source and deliver a constant 800maH.They can charge/balance 2 and 3 cell lipos via the two inputs.http://www.rcmdirect.co.uk/store/index.php?main_page=index&cPath=101_78 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted January 24, 2008 Share Posted January 24, 2008 Amberbike - the Skylift charger is for 3s only It has a plug-in JST-XH socket and you'll find the 2S has a smaller plug and so wont fit in the socket hole on the charger. Quote Link to comment Share on other sites More sharing options...
amberbike Posted January 24, 2008 Author Share Posted January 24, 2008 Thank u david & david had a look on rcmdirect link & think i will go for david martin 2 suggestion & buy charger & battery they seem reasonably priced,thanks again guys. Quote Link to comment Share on other sites More sharing options...
David Martin 2 Posted January 30, 2008 Share Posted January 30, 2008 Amberbike, once you have the RCMDIRECT charger, you may like to look at the 2 cell lipos on the GIANTCOD website, very reasonable price for our FP helis....http://www.giantcod.co.uk/lipo-battery-cell-lipo-battery-c-1_113.html?osCsid=7a96cc0fc2e2da0f3145ae22988b97bcThe lower 800mah pack for £6.17 will be much lighter than the current Nimh pack you're using and give a longer duration.Cheers. Quote Link to comment Share on other sites More sharing options...
