Winco Steve Posted December 15, 2012 Share Posted December 15, 2012 Good morning all, I have just attempted to bind a Futaba R2006GS receiver to my 6J. All very easy stuff. However, I did encouter an interesting incident. Whilst going through the process I noticed that the receiver LED continued to flash red (not binding) and would not go to the solid green of 'bound'. I disconnected the receiver power and switched off the transmitter. Tried again, same occured. I then realsied that the whole set up was quite close to my computer router. Now, I know these, or mine anyway, operate on the 2.4 GHZ range. So, I moved out of the room and into another and the process worked within a couple of seconds. So, I suppose I'm just letting anyone else know that this can be a something to watch out for when attempting to bind receivers! If a router can, apparently, cause effect it may be possible for other devices on the 2.4 spectrum to do the same. Regards to all, Winco Steve Edited By Winco Steve on 15/12/2012 09:11:11 Quote Link to comment Share on other sites More sharing options...
simon barr Posted December 15, 2012 Share Posted December 15, 2012 Cheers Steve, thanks for that. I have noticed this before, but its good to put it out there so others know. We also had a binding issue at our indoor meet the other night, where three guys were trying to bind their new mini quad copters at the same time, but only one tx got through and locked into all three quads. It was funny, but also a bit dangerous as the other two started up while their owners were handling them. Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted December 15, 2012 Author Share Posted December 15, 2012 HI Simon, Thanks for the reply. Yes, my main purpose was to alert others to this problem which, at the time, I had never encountered. Interesting about the example you give, could have gone terribly wrong! Kindest regards, Winco Steve Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 27, 2020 Share Posted September 27, 2020 We ave been trying to bind a Futaba T6K with a Futaba R2006gs receiver. The Tx is on S-FHSS and the Rx is the same protocol. We’ve had no luck binding, what are we doing wrong please.....desperately need a solution. Quote Link to comment Share on other sites More sharing options...
