JC Posted March 24, 2013 Share Posted March 24, 2013 Hi folks just a quick one. The instructions for the MPX Fun Jet Ultra call for negative differential, I just want to be sure that this means more down than up as I have not come across this before. Cheers JC Edited By JC on 24/03/2013 08:47:21 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted March 24, 2013 Share Posted March 24, 2013 JC That is certainly the meaning I would put on 'negative differential' but it is very unusual as it would increase any adverse yaw and its not called adverse without good reason! Do the instruction give any sort of diagram of the effect they intend? Quote Link to comment Share on other sites More sharing options...
JC Posted March 24, 2013 Author Share Posted March 24, 2013 Thanks Simon. No there is no diagram just instructions to set the throws to plus 8 and minus 11. Minus 11 seems a bit much to me. The Fun Jet is quick and I think it will only need very small movements of the control surfaces or it would be all but unflyable. Cheers Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted March 24, 2013 Share Posted March 24, 2013 I don't remember ever coming across negative differential - even as a term! The Funjet has elevons doesn't it? If so could they be describing the additional throw required to ensure that you can get full aileron and full elevator effects at the same time? BEB Quote Link to comment Share on other sites More sharing options...
