Mike Gunn Posted April 9, 2013 Share Posted April 9, 2013 Hi all I have just bought 2 used ar6000 receivers hoping to use them with my Dx7s and cannot get them to bind. I have read reports on the net that say these receivers may not work with the newer Dsmx transmitters, so tried my Dx6i which would not bind either. I'm unsure whether my 6i is DSM2 or DSMX so I dragged out an old LP5DSM transmitter and guess what....that too will not bind with either receiver. It is badged as DSM2 Am I looking at an incompatibility problem or are both receivers faulty, which seems unlikely? I thought that the DSM receivers were compatible with DSM2 at least. Both receivers fast flash orange when the bind plug and power are connected and I am going through the same process as I do with all my other receivers. cheers....Mike Quote Link to comment Share on other sites More sharing options...
crispin church Posted April 9, 2013 Share Posted April 9, 2013 AR6000 ? or AR600 ? post a photo what it looks like if AR6000 this is dsm will not work with dx6i or above they need dsm2 have you had many rx and in past bound them ok? Quote Link to comment Share on other sites More sharing options...
Alan Randall Posted April 9, 2013 Share Posted April 9, 2013 The AR6000 works with the old DX7 but not with the DX6i, DX7S & DX8 etc. Quote Link to comment Share on other sites More sharing options...
Mike Gunn Posted April 9, 2013 Author Share Posted April 9, 2013 Hiya Thanks for getting back. I had just remembered I still had 1 more transmitter to try, it came with a small blade heli that I bought. Tried that and they both bind ok even though the little transmitter is marked as DSM2 as well The receivers are the old style AR6000 park flyer types and as you say are DSM.I have loads of others both orangerx and Spektrum and they are all fine. It would appear though that they work with some types of DSM2 transmitters as the little £5 one seems to be fine. I should have done more research before buying them. Ho hum....guess they will have to go to the flea bay.....lol Thanks....Mike Quote Link to comment Share on other sites More sharing options...
Pete B Posted April 9, 2013 Share Posted April 9, 2013 As far as I am aware, the Dx7s being DSMX is not compatible with DSM receivers. The Dx6i, if it is DSM2, should bind with the AR6000. If it has been upgraded to DSMX, it won't work with the AR6000. Your Dx6i should have the appropriate badging near the screen. It might help with binding if you make sure the Rx is a metre or further from the Tx. Pete Quote Link to comment Share on other sites More sharing options...
Mike Gunn Posted April 9, 2013 Author Share Posted April 9, 2013 Thanks Alan Must remember to use brain before buying. Only saving grace is they seem quite rare now and one went on ebay recently for a good price so guess I might get my money back now that I know they work thanks....mike Quote Link to comment Share on other sites More sharing options...
Mike Gunn Posted April 9, 2013 Author Share Posted April 9, 2013 Hi Pete Thanks and you are right....both my Tx's are DSMX. Still strange why the old 5 channel set would not work though as it binds with everything else and is marked as DSM2....guess it could be an upgrade inside a standard case? Quote Link to comment Share on other sites More sharing options...
