bouncebounce crunch Posted May 30, 2013 Share Posted May 30, 2013 Finally got some shed time today, after many months, (my poor Cub, she been lonely)so had a go at this. Will this brass in brass sort of scale work? this is my first mock up attempt, bolts are brass m1. a little toe in to help my slow reflexes. I hope this works, not been on the scales as yet. any feedback very welcome. i have bashed and thrown the soldered parts around a bit, just to see if it will hold, and all seems well so far. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 30, 2013 Share Posted May 30, 2013 Is it all brass BBC? If so isn't brass a bit soft for this job? BEB Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted May 30, 2013 Author Share Posted May 30, 2013 BEB thanks for your help. I have brass with next diameter down inserted 1cm each end and soldered, piano wire is the other metal for cross bracing and the axle. alloy fixings. this may only last as a static but a good learning experience all the same, and i will still make the plan version for flying. bbc. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 30, 2013 Share Posted May 30, 2013 Looks good. I like the scale bungies! BEB Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted May 30, 2013 Share Posted May 30, 2013 I built a similar fully working U/C for my 1/6th Jungmeister, on that I used brass end fittings on piano wire radius arms the first time around, and guess what? The brass pivots failed over a half dozen landings with the 3mm bolts pulling through the holes, even with two thicknesses of brass tube. They're now flattened steel tube ends silver soldered to the wire legs and have survived ok so far. Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted May 30, 2013 Author Share Posted May 30, 2013 Thank you both gentlemen, not tried this before and sitting in the shed experimenting on your own you always learn the hard way (well i do). so thanks for the input , now thanks Bob I have a clearer idea of how a working set may be viable. bbc Quote Link to comment Share on other sites More sharing options...
