John Roberts 9 Posted July 31, 2013 Share Posted July 31, 2013 Hello I friend generously gave me a lightly damaged PA Addiction (now repaired) but I don't have the build manual. Could someone post the recommended control throws and CG so that I can finalise my set up please? It doesn't look as though PA make their manuals available on their web site and a google search didn't throw up very much in the way of helpful set up data. Thanks in advance for any help you can give. John Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted July 31, 2013 Share Posted July 31, 2013 OK from the manual c of g - 100 to 105mm from the leading edge of the wing tip Ailerons - High rate 40-45 Deg - 70% Expo, Low Rate 15-20 deg, 30% Expo Rudder - High Rate 45 Deg max 70% Expo, Low rate 25 deg 35% Expo Elevator - 45 Deg 70% Expo, Low rate 15-20 deg 30% Expo it flies a treat, when I waggle the sticks in the pits some think it will be very twitchy, but I don't let on what a great flier it is, one of my favourite tricks is flying it round at waist height doing walking pace flat turns using the rudder and opposite rudder. Best in light winds but a lovely plane. I use 1750 mah 3s lipos in mine. Edited By Frank Skilbeck on 31/07/2013 20:11:56 Quote Link to comment Share on other sites More sharing options...
John Roberts 9 Posted July 31, 2013 Author Share Posted July 31, 2013 Hello Frank Thanks very much for taking the time & trouble to find & post this information for me. Very much appreciated . Cheers, John Quote Link to comment Share on other sites More sharing options...
