Masher Posted August 29, 2013 Share Posted August 29, 2013 Please can anybody help with the plans or build instructions for the Fair Pulsar? I have aquired an unstarted kit in the box but unfortunately there is no documentation. I believe this is a 1980's kit which has a very good reputation. Thanks Quote Link to comment Share on other sites More sharing options...
kevin b Posted August 29, 2013 Share Posted August 29, 2013 You may get help here. **LINK** Have you tried contacting Flair themselves, to see if they can help ? kevinb. Quote Link to comment Share on other sites More sharing options...
Masher Posted August 30, 2013 Author Share Posted August 30, 2013 Thanks Kev I have seen that thread which helps a lot. I've also found an A4 scan of the plan - it's not readable but gives a few clues. I will try flair too. Thanks Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 30, 2013 Share Posted August 30, 2013 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Masher Posted August 30, 2013 Author Share Posted August 30, 2013 Hi Percy Yes it has a nice shiny red fiberglass fuse! Nobody seems to have come up with a plan yet so looks like I have to work it out for myself. Quote Link to comment Share on other sites More sharing options...
Masher Posted September 2, 2013 Author Share Posted September 2, 2013 Well I followed the advice and spoke to Flair and there was good news and bad news. Catherine at Flair was very helpful and even went to check the drawings ............ but as she thought they only have drawings for current models so they couldn't help. This is because of the change of ownership in recent years. Still, nice to know they would of helped if they could So having had the kit of bits out of the box, it is not immediately obvious who to stick them together. I've been told to pull off the existing veneer from the wings (it is not bad condition but lifting off the foam quite a bit) and replace with 1/16th balsa. Also the embedded aileron servo snakes are at too tight a radius back to the central servo so best to scrap and use individual wing servos Once again, please can anyone help with plans or instructions? Thanks Quote Link to comment Share on other sites More sharing options...
AlbertBallVC Posted September 25, 2013 Share Posted September 25, 2013 Just read your request, I have a set of plans & also I believe some building iinstructions. I'm working away & will look for them when I get home. Quote Link to comment Share on other sites More sharing options...
Masher Posted September 25, 2013 Author Share Posted September 25, 2013 Thanks very much Peter that will be much appreciated! I have drawn a blank so far and this is great news Martin Quote Link to comment Share on other sites More sharing options...
AlbertBallVC Posted September 25, 2013 Share Posted September 25, 2013 hello Martin, I have some images of the plan & also an exploded view with me. If you would like to email me at [email protected]">[email protected] i can send them to you to look at for the time being. Quote Link to comment Share on other sites More sharing options...
AlbertBallVC Posted September 25, 2013 Share Posted September 25, 2013 Quote Link to comment Share on other sites More sharing options...
Masher Posted September 26, 2013 Author Share Posted September 26, 2013 Thanks Peter, pm sent. It's surprising how much information you can get out of these small images - there aren't that many bits but still quite a few ways to stick them together wrongly without a picture! Thanks Martin Quote Link to comment Share on other sites More sharing options...
