Biggles' Elder Brother - Moderator Posted February 3, 2014 Share Posted February 3, 2014 Posted by Braddock, VC on 03/02/2014 13:56:57: I've planned the scheme in my head, I have a metre of metallic violet profilm which will cover the upward facing bits aft from halfway between the tailplane leading edge and the t/e of the wing. Undersides of tailplane, wing and fuse in black and white checkered film rest of fuse and wing top surface in cub yellow profilm and I have some holographic stick on film to put the leading edge wot 4 trims on. Well you certainly won't lose it by the sound of things! Should be able to see that in the dark! Sounds great! BEB Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 14, 2014 Author Share Posted February 14, 2014 Final sanding of sanding sealer put on hold as it's an outside job and the rain is raining and the wind is blowing a hooligan. I'm off for a few days doing the family rounds then next friday I'm going to take out the throttle servo from the central position and pop an hitec 85 mg as the throttle servo under the cowl. At the same time I'll look at taking out the rudder and ele servos and replace them with 38 gramme 4.2 kg/cm digitals in the after end of the fuselage. IIRC I prefer the old wottie with an aft c of g and it's a wee bit easier to fasten lead to the engine mount than to the tail. I'll run a test with the a/c assembled and the servos lying on the fus top to see how much ballast it needs before committing myself though. I really don't like how chris foss suggests installing the wing servos, not lying on their side and mounted with the complete output arm out in the breeze, very vulnerable. To late to do anything now though. Edited By Braddock, VC on 14/02/2014 23:45:52 Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 25, 2014 Author Share Posted February 25, 2014 Fuse and tailfeathers sanding sealer postponed again, got all the servos mounted though and taken out again so I can cover the thing, not looking forward to that. Put a second coat of fuel proofer inside and round the cowl area, I'll pop a tailwheel on tomorrow. Quite pleased with the ways things are going as I've set up my wot4 foame and the radian pro, bought both of them a year or so back so I'll have a few planes to play with. Got my falcon down from the loft, one of the engine bearers has become unglued, this is a problem as the plane is now 11 years old and a bit oily inside but I'll sort it out I'm sure, "a bit at a time" Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 25, 2014 Author Share Posted February 25, 2014 I couldn't believe it when I saw the time of that last post, I've been faffing around for nearly 4 hours just to pop a few servos in flipping heck! Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted April 12, 2014 Author Share Posted April 12, 2014 Final sanding now done, ailerons trimmed to length and leading edges of ailerons vee'd up. All plastered with sanding sealer and wants a quick rub down with really fine sandpaper then onto covering it which I'm still not looking forward too. Hope to maiden it on the BH weekend with a bit of luck. Quote Link to comment Share on other sites More sharing options...
Pete B Posted April 12, 2014 Share Posted April 12, 2014 ...and only a couple of months to create some dust and slap on a bit of sanding sealer - that's still faster than me! Last lap now - good luck with the maiden Pete Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted May 8, 2014 Author Share Posted May 8, 2014 Hit a block, I have the wot 4 ready to cover together with a kit built acrowot also ready to cover and I really am struggling to get motivated to finish them. FWIW I fuel proofed both the fuselages and also the wings out as far as the aileron roots then rubbed that back with wet and dry so it really is a matter for "just" covering which is my least favourite part of building. What I'll probably end up doing is ditching the flash covering scheme I had in mind and do them both in Cub yellow profilm with a few bits of trim . Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted May 8, 2014 Author Share Posted May 8, 2014 Forgot to mention I've come up against this wall before, I have two carl goldberg kits built and waiting for covering (one's been waiting more than 10 years) and a BT hurricane too. Oh and a galaxy foxjet. Perhaps I'm destined for artfs....... Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted October 10, 2014 Author Share Posted October 10, 2014 All covered bar the ailerons and elevators, did my usual nora batty covering job. Popped over to ashford for some ammo for my gun and called into ashrofd model supply to get some fittings to connect up the rudder, the fossy way looks heath robinson to me. I used corona digitals for the wing servos, absolute cheap tat, the lugs snapped clean off one as I screwed the thing on and no, I wasn't pulling the damn things in with the screws. So now they are held in place with expanding foam! Hopefully it should fly within a few weeks. I'll move onto the acrowot when this one is done. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted July 1, 2015 Author Share Posted July 1, 2015 Well, it eventually maidened about 4 weeks ago, and it flew well on a laser 70 then I finally got mysaito 82 sorted and that makes it really perform, well pleased with the result, One bit at a time works so well! Just over two years start to finish. Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted July 1, 2015 Share Posted July 1, 2015 Well done for finishing.................. I hate covering...............as three planes backlogged demonstrates! Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted January 12, 2016 Author Share Posted January 12, 2016 I thought I'd drag this out for an update. Wottie flying well till the engine seized. Have freed it up, crankpin seized the conrod engine now runs fine but the flying field is yeuk. Finally finished the acrowot, fitted another saito 82 to it when I decided to sell off the saitos and go back to OS. The saitos were snapped up and now I have to fit a new s/h os 61 fx in the wot 4 and a s/h os 91 fx in the acrowot. Work on hold as my mojo is slipping due to my tax return needing completion. Ho hum, roll on feb 1. Quote Link to comment Share on other sites More sharing options...
