Jon Laughton Posted March 4, 2014 Share Posted March 4, 2014 I'm thinking of buying one of these for an OS55AX engine: does anyone have any experience of the model and in particular how robust the retracts are? Thanks Jon Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 4, 2014 Share Posted March 4, 2014 They are plastic trunnioned cheap and basic mechanical units - mine has been operating from grass for several years and they haven't missed a beat! Oddly, one of the legs seemed a bit soft - it sometimes bent enough on taxi and take-off to cause the wheel to foul the wheel well when I retracted it but after quite a few straightenings (I knocked up a bending tool for the flightbox) it seems to have work hardened and has remained straight for a long time now. Mine flies very nicely on a 46 AX although it would be even better with the 55 It flies like it's on rails and is at its best doing large scale type manoeuvres. Seems a very well constructed and robust ARTF with a very nice fibreglass fuselage. Mine survived a flat out touch and go - with the undercarriage up - when I got a bit overconfident and just removed both prop blades and the radiator which only needed the wooden braces gluing back in! Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted March 5, 2014 Share Posted March 5, 2014 i'm in the process of repairing one that got given to me after an aileron rod gave way , totally ripping one wing off . But they do fly very nice , this one has fixed uc , but my mate aqcuired it like that from a swap meet Quote Link to comment Share on other sites More sharing options...
Jon Laughton Posted March 5, 2014 Author Share Posted March 5, 2014 Sounds like it does what its claimed to do so will be investing in one! I note that the on line manual gives quite small deflections for the ailerons - Martin is this how yours is set up? John - good luck with the repair: I'd like to know how you get on when she's back flying.. Cheers Guys Jon Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 5, 2014 Share Posted March 5, 2014 I haven't checked the manual but mine are set at about 5/16 (or 8mm) either way. This gives plenty of control for "appropriate" flying for the model. I had an "interesting" moment with the model when one aileron lead pulled out of the receiver and left one of the ailerons deflected at pretty much full movement - as I corrected the roll it pitched significantly and my first thought was battery failure but it was controllable with pretty much full aileron applied and quite a bit of elevator (to counter the pitching effect of 2 ailerons deflected the same way in level flight). I landed wheels up immediately, still suspecting imminent radio failure but on approaching it the problem was obvious. The reason it pulled out? Contrary to my normal practice I'd made a nice "loom" of all the receiver connections and I think the G loading on the combined weight had pulled on it and thankfully it was a single aileron lead that was the shortest... As a bonus, if you ever have to land wheels up, you'll find that the radiator will withstand a reasonable landing without damage on grass! Quote Link to comment Share on other sites More sharing options...
Tom Ling Posted December 27, 2015 Share Posted December 27, 2015 Iv got one, I ran an asp 90 same size as the 60 in mine a big nose heavy but flew lovely unfortunately it's damaged when the engine quit on take off, in the air it was great but it needs respect on landing, mine liked to tip stall when slow but come in a little bit faster and it was really smooth, the undercarriage was pants it bent when I left in in a room on its gear for a weekend .... Would 100% change them straight away for electrics, if I could work out to photos on id put some up lol Quote Link to comment Share on other sites More sharing options...
Tom Ling Posted December 27, 2015 Share Posted December 27, 2015 Quote Link to comment Share on other sites More sharing options...
Tom Ling Posted December 27, 2015 Share Posted December 27, 2015 I got the cowl cut well and it flew lovely went like stink!! Probably a "little" nose heavy but I had an asp 62 4s in it to start with and it just didn't fly well with it in, so the only way was up Quote Link to comment Share on other sites More sharing options...
