Erfolg Posted April 10, 2008 Share Posted April 10, 2008 Can I use a synthesizer receiver with a non synthesizer transmitter?Erfolg Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 10, 2008 Share Posted April 10, 2008 With some yes....see here Quote Link to comment Share on other sites More sharing options...
Erfolg Posted April 11, 2008 Author Share Posted April 11, 2008 TimboThe reviews are some what mixed.For some it is no good, others seem to have reservation, and the remainder seem to think its good to the best thing from sliced bread. The trouble with this type of review (given that there is no time line to work out the history), is that they can be like "Imax 6". Some reviewers quoting all sorts of problems and inaccuracies. Yet for me it works fine, accuracy is great.I am not sure what is a reasonable performance from a receiver, I guessRangeRejection of unwanted signalsAccuracy of converting signal to out put.Have I missed something?How do you really measure these things objectively and put the result in context.Erfolg Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 11, 2008 Share Posted April 11, 2008 Unortunately as we know, the only REAL test of performance is when its flying your pride and joy around the sky.I guess you could always email the manufacturer concerned and see what they say? Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 11, 2008 Share Posted April 11, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Erfolg Posted April 12, 2008 Author Share Posted April 12, 2008 I said I was confused in another thread, seems I am suspetable to it now, or possibly totally lacking in knowledge.If the Tx crystal can drift, will this not affect a crystal Rx?If the Syn Rx, fixes on the frequency that it percieves the Tx is sending, will this not be more accurate?Or do the Syn Rx pick up on allocated frequencies?Do you have to reset the Rx every time you power up the Rx. Or does it lock onto a frequency until it is reallocated?Erfolg Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted April 12, 2008 Share Posted April 12, 2008 To quote (somewhat badly) George Bernard Shaw.. "Science solves one problem and creates many more." Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 12, 2008 Share Posted April 12, 2008 YesYesNoI believe the second part of the answer is correct.Mind you I could be wrong...it has been known and I have never actually owned a 35Mhz synth set....went straight to 2.4 from 35mhz. Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 12, 2008 Share Posted April 12, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 12, 2008 Share Posted April 12, 2008 Well actually I think it is still YYN! The second question was basically asking is a synthezied receiver not likely to be more accurate than a crystal based one ( or a tleast that how I read it ) and therefore in this respect, YES is the correct answer. The synthesized receiver does use an "allocated" frequency ( as per being set to the frequency you tell it to lock onto by sending a strong signal from your close-by tr ) It doesnt get allocated one as such ( like a 2.4ghz set does )probably just terminology and different interpretation of the questions Eric.... I blame Erfolg Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted April 12, 2008 Share Posted April 12, 2008 As my memory serves (or fails) me a free running synthesizer retains its memory only when an internal battery is included within the apparatus. Is this receiver free running or direct synthised?Crystals within the transmitter (and also crystal controlled receivers) drift due to changes in temperature, several ppm between freezing and a warm summers day. A 'locked on' receiver will not.Where does that leave us? Quote Link to comment Share on other sites More sharing options...
