David Kennerley Posted March 25, 2014 Share Posted March 25, 2014 Hi Dose anyone have any information about fitting flaps to the wings on the original foam wing db spitfire I picked up an old kit witch I'm building and need to make the decision to fit flaps or not to ? Cheers Kiwi Dave Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted March 25, 2014 Share Posted March 25, 2014 Nope but you can buy a wing kit separately from db, Quote Link to comment Share on other sites More sharing options...
reg shaw Posted March 25, 2014 Share Posted March 25, 2014 Hi Dave, you can add flaps to the original wing, you can even add the 'Spitfire gull' trailing edge at the root without to much issue. My flaps were fitted after the wing was sheeted, but the thinking was done before I started any of it so I knew (ish) that it would work. The foam was removed completely from where the flaps would be and a spar added to hang the hinges off. I moved the wing mounting bolts forward to hide them under scale panels. My mods were all done after studying the Brian Taylor MkI Spitfire plans, since the design work is all done, we just need to resize it all to fit the DB wing. I'd definately fit flaps, makes landing so much easier and scale like! I'll see if I can find some pics but it was years ago so don't hold your breath!!! Ian. Quote Link to comment Share on other sites More sharing options...
David Kennerley Posted April 12, 2014 Author Share Posted April 12, 2014 Thanks for the replies guys I think I will fit flaps Have just epoxied wings together so next job fit braces retracts and flaps Ian if you can find those pictures it would be a great help Cheers kiwi Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted April 12, 2014 Share Posted April 12, 2014 Some pics of the mods I made to a rebuild DB Spit with foam wing. Much as Ian (Reg) says, cut away all the foam and drop in a spar to fix the hinges too. I simply cut away the underside down to the top skin veneer and removed all the foam. Glued in a new hard balsa spar from 6mm wide sheet cut to depth and then fixed robart hinges at 45 degrees leaving just the hinge point proud of the surface. I went for 4 section flaps and the connections between flaps are just tube glued into the main flap with a rod fixed to the inner so that it slides in the tube so both flaps of each wing are operated by just one servo. Servo's were mounted in the underside of the wing aft of the retract wells and wires run through / under the retract wells to hide the wires. Well worth the effort and not as big a job as it first feels. Linds Quote Link to comment Share on other sites More sharing options...
David Kennerley Posted May 2, 2015 Author Share Posted May 2, 2015 thanks for the feed back as you can see from the dates not rushing this build here are some up date pics Quote Link to comment Share on other sites More sharing options...
