Martyn Perks Posted April 15, 2014 Share Posted April 15, 2014 Morning everybody Am in the process of repairing my ST Blaze after piling it in nose first into a soft field! Its about the foam really. Some of it has been compressed and I have successfully straightened the fuselage by heating it with boiling water and the off strategic cut. Was planning to repair with epoxy but to my suprise it didn't stick when i tried a test piece. The model seems to have been assembled using White silicone-Is this the ordinary stuff from Band Q or is there a model specific version? Thanks Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 15, 2014 Share Posted April 15, 2014 hello martyn.......have a go with some foam friendly cyno....it will do the job.. ken Anderson ne...1 cyno dept. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 15, 2014 Share Posted April 15, 2014 I've had good results with Gorilla glue on my Wot foamie and Formosa II, it fills any remaining gaps and stays slightly more flexible than CA which is always a good thing Quote Link to comment Share on other sites More sharing options...
Bill_B Posted April 15, 2014 Share Posted April 15, 2014 Foam safe Cyano isn't recommended for EPO due to lack of ultimate strength, regular Cyano should be used, with a kicker if necessary. Foam safe is best kept for Depron and EPS foams. Quote Link to comment Share on other sites More sharing options...
KingKade Posted November 24, 2015 Share Posted November 24, 2015 Thought id hijack this old post and ask a simple blaze question. How do you remove the prop adaptor from the motor? Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 25, 2015 Share Posted November 25, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 25, 2015 Share Posted November 25, 2015 local heat with a soldering iron on the prop driver hub should get it off also.... ken anderson...ne...1 heat dept. Quote Link to comment Share on other sites More sharing options...
KingKade Posted November 25, 2015 Share Posted November 25, 2015 thank you guys! will try those ideas now. Quote Link to comment Share on other sites More sharing options...
