Glow plug driver advice please
Hi I just bought a glow plug driver that can be switched either manual on-off or using a separate channel on tx. I am concerned that should I forget its on it will drain rx battery and you know the rest.
it draws it power through the rx. Can I change this but still use the rx to switch it on-off? If I take the red pin out of the plug and wire it to a positive on a separate battery, then take a negative and wire that to engine and separate battery will that work?
I have a couple of the HobbyKing ones in use (on 50 sized glow Helis). They work well using a single flight/glow battery, but then I'm using a 3700mAh 4 cell "C" sized pack (which are my std pack size for std digital equipped Helis.
Yours should work OK wired as you say like a UBEC/Opto ESC paired system of connection, but it's easy enough to test.
