Rob Jones 2 Posted May 24, 2014 Share Posted May 24, 2014 HI, I have just fitted a small HK BL motor, fully enclosed in the front of a Lanyu built-up E-Fair sailplane.After fitting it, I realised it is a neat job, but I have made no provision for venting it.I intend to use the motor just briefly, to get to height to look for thermals.Do you think it will overheat, or will i get away with if? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 24, 2014 Share Posted May 24, 2014 Quite a few moulded gliders at our club Rob, they fly as you intend too and have no probs. John Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 25, 2014 Share Posted May 25, 2014 I agree with John. Especially as you will only run intermittently I can't see the motor being too troubled by thermal effects. The same might not be true for your ESC - which in most installations is more critical. But provided you've spec'ed it with a reasonable headroom that shouldn't be a problem either. BEB Quote Link to comment Share on other sites More sharing options...
