Steve Houghton 1 Posted August 13, 2014 Share Posted August 13, 2014 I'd love to be able to get into PSS but I don't have the facilities at home to be able to build a balsa model. My only truly flat surface for building a wing is my kitchen work top, which isn't practical. So I'm limited to building EPP only or buying ready built second hand models. So apart from LEG in the USA, does anyone know of a supplier of EPP PSS planes? Steve A470soaring.blogspot.co.uk Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted August 13, 2014 Share Posted August 13, 2014 http://www.vortex-vacforms.co.uk apparently do some, but their website is shockingly bad Quote Link to comment Share on other sites More sharing options...
Steve Houghton 1 Posted August 13, 2014 Author Share Posted August 13, 2014 You're right Andy, it's an appalling web site. I can't even access a list of the kits Quote Link to comment Share on other sites More sharing options...
Jamie sawyer Posted August 13, 2014 Share Posted August 13, 2014 Hi steve, I don't either but I still love building. I have a portable building board and it is very easy to slip out of the way while your not using it. Just get the main building of the wings done asap so you dont get sick of seeing it lying around. My one is an MDF sheet about 600mm x 1200mm. Just slip it under the bed when its not in use .......If your worried about the board twisting just buy a steel 1m rule to check it for twisting. As a confesion I actually have a wing that is slightly twisted but hey ho its very easy to get a minor twist out. Quote Link to comment Share on other sites More sharing options...
