Andy Freeman Posted May 9, 2008 Share Posted May 9, 2008 Bought a zagi in a moment of weakness. Got the box home and opened the instructions and boy are they poor. I realise that there is nothing that can really go wrong in the construction but the covering advise is V. poor. Covering in glass tape is mentioned (actually recomendedbut) at no point does it say where to use glass tape. Do i cover it all? Leading edges? do I actually need to bother?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 9, 2008 Share Posted May 9, 2008 Generally these type of hard used wings get completely covered in the cross weave tape, then coloured parcel tape is put on top to give colour and more importantly protect the crossweave tape from UV light which quickly dries out the glue and it then becomes useless. Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted May 9, 2008 Author Share Posted May 9, 2008 Thanks Timbo...... Cross weave tape to be purchased....... Quote Link to comment Share on other sites More sharing options...
Peewhit Posted May 9, 2008 Share Posted May 9, 2008 Can use a film covering on top of the CW tape to give colour - would recommend Profilm.Just lightly sand the CW tape and wipe with white spirit - this removes the release agent which stops the tape sticking to itself on the roll.Assuming that the Zagi is EPP foam, you can use an iron temperature os about 300 degrees FARENHEIT, which adheres the profilm nicely.Did this on my Bedlam and it looks really good.Butt join the CW tape instead of overlapping and you get fewer joint lines. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted May 10, 2008 Share Posted May 10, 2008 just call up www.zagi.com or Google Trick R/C, you will find comprehensive instructions and loads of other info'/tips etc. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted May 10, 2008 Share Posted May 10, 2008 Oh - and I have just film covered a Sylvan Prodigy - prep'd the bare foam with Balsaloc, good adhesion once you have "tuned" your iron, film sticks well to the c/w tape as stated above if wiped with meths. Quote Link to comment Share on other sites More sharing options...
twinstar Posted August 13, 2008 Share Posted August 13, 2008 i put a carbon spar in my zagi, backfilled the hole with foam and "Spackle" (the readymix lightweight polyfiller, then used some x-weave tape in strategic places (refer to yourzagi.com)..., light sand then spray with spray on adhesive 3m77 or carpet adhesive etc, ironed on profilm, start from the centre and work outwards. in retrospect it was a lot of effort for what tunred out to be a dissapointing model, it needs quite a decent wind at my local hill to stay up, and setting it up well is critical. unlike all my other models, it never really behaves itself and goes where its told. i shouldve bought a wing from phoenix model products instead, but at least i dont mind if it hits a tree, fencepost, or if i reverse over it in the car parkthe Xit is a better wing than the zagi as its all EPP, the zagi only has an EPP leading edge the rest is cheapo polystyrene! Try to build it light, mount the servos quite far forwards and youll need less lead to balance it. Quote Link to comment Share on other sites More sharing options...
tony adlam Posted January 6, 2009 Share Posted January 6, 2009 Please please help..I live in kent and want to buy a zaggi.....can anyone help me ? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 6, 2009 Share Posted January 6, 2009 Living in Kent should not be barrier to buying a zaggi Tony...indeed the forum administrator himself lives in that very county.... and he manages to get all sorts of aeroplanes Quote Link to comment Share on other sites More sharing options...
Matthew Lloyd Posted January 6, 2009 Share Posted January 6, 2009 I thought Zaggis were ten a penny - everyone sells them. Try SMC or any other online retailer.Better still, buy a Wildthing! Quote Link to comment Share on other sites More sharing options...
