Folding prop help.
Bugbear
I'm currently building a West Wings Fournier and have hit a snag with fitting a folding prop - it catches on the dummy engine pods either side of the fuselage.
Is it possible to adjust the angle of fold-back or should I just use a fixed prop instead.
Any advice welcome.
Thanks
It's not an issue I've encountered with mine in practice, Bugbear. Whilst the prop does contact the pods when folded, startup just throws them outwards and I've never had any motor stalling occur.
I have a 32mm spinner like this on mine - your motor may have a different shaft diameter. Perhaps the extended blade bolts solve the problem?
A fixed prop will work but will have an additional drag factor compared with a folder, even with the motor brake set.
Pete
