My C7 own design jet trainer/Home engineered kj66 turbine
stevejet66
This is my own design high wing jet trainer, Home engineered KJ66 gas turbine, The only parts i brought were the compressor wheel, Turbine wheel and n.g.v, No fadec or any other type of ecu, Its all programmed using the throttle curve on the transmitter, Its set to give 12lb's of thrust and can be adjusted to give more or less, It as three safety shut down features,This is stage 5 of engine testing and is now ready for its maiden flight,
Edited By stevejet66 on 28/06/2015 08:13:11
  • 1 year later...
