zz Posted July 11, 2015 Share Posted July 11, 2015 Hello, I have a foam warbird kit and I want to remove the vynal decals from it and replace with markings of a different nationality. I don't want to damage the underlying camouflage paint. I thought applying gentle heat may weaken the adhesive and allow me to ease the decals off. The kit is still in the box, just gathering my thoughts. I would appreciate any thoughts/suggestions. Thanks. Quote Link to comment Share on other sites More sharing options...
Jack Rogerson Posted July 11, 2015 Share Posted July 11, 2015 I think heat is the answer. I have never done exactly what you are trying, but have removed decals from other items. You really need to try an area to practice on, if that is possible. Use a heat gun, but from a distance away, not close up. The vinyl should go soft before the foam gets damaged. If you think a heat gun is too hot, use a hair drier, with the air intake blanked off a little, to increase the temperature. As with all things, tread carefully. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted July 11, 2015 Share Posted July 11, 2015 hello Ian...I removed them from a couple of models...gentle heat is the way--they come straight off ........and if your lucky will leave the paint intact..... ken Anderson...ne....1 ...gentle heat dept. Quote Link to comment Share on other sites More sharing options...
