Shane Sunday Posted July 27, 2015 Share Posted July 27, 2015 Is your tailplane a built up afair like the wing? If so why not bury the servos in the tailplane the same way you would with the wing? Only the servo arm s would be parallel to the fin. Sorry vertical stabiliser. If your horizontal stab is not a built up jobby, you could still bury it in a cavity that goes straight through the stab. Meanwhile the servo fills the hole Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted July 28, 2015 Share Posted July 28, 2015 Are you desperate for a rudder ??, bit off topic regarding linkage for twin rudders. This is my Skyfarer built from the Phil Kent plan and does not have rudder control, only a steerable nose wheel and ailerons and elevator. I gave Phil a call to ask him about the rudder control and seemingly the design of the aircraft was to try and eliminate the possibility of spinning. The Americans had lost a few pilots due to spinning accidents and the rudder being the culprit causing the spin. My model has not flown yet but I have Phil's word it flies very well without rudder control. Food for thought ?? Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted August 4, 2015 Author Share Posted August 4, 2015 very smart model there Jim Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted August 4, 2015 Share Posted August 4, 2015 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 4, 2015 Share Posted August 4, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted August 4, 2015 Share Posted August 4, 2015 My worry with a model of this type with no rudder is adverse yaw,high wing models of the Cub/silvaire type have this problem,aileron differential is the answer but I'll have to wait and see proof of the pud.?? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 5, 2015 Share Posted August 5, 2015 The other answer would be Frise ailerons. A bit late for them now. I am doing a scale model at the moment which has FRise ailerons. Going to be interesting to see how well they work. Quote Link to comment Share on other sites More sharing options...
