daveyboy Posted April 28, 2016 Author Share Posted April 28, 2016 So as you can see foam inserts have been shaped and secured in place. The whole fuz can now be sheeted phew !!! that will take ages !!!,Blue foam is used as recommended but light balsa would do the same. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted April 28, 2016 Author Share Posted April 28, 2016 Thought i was lucky enough to have a nice spacious building room, this little beauty fills the space. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted April 28, 2016 Author Share Posted April 28, 2016 Getting there slowly but lots of enjoyment building this. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted April 28, 2016 Author Share Posted April 28, 2016 I will set the tailplane mounts over night then i can start sheeting, better buy some more balsa !!!!. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted April 28, 2016 Author Share Posted April 28, 2016 Done some basic shaping on the cowl but it must be said it will need quite a bit of work to get things smooth and acceptable. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted May 17, 2016 Author Share Posted May 17, 2016 Hi folks, Well a bit of a lull in the build as i am waiting for the show season to start and i can purchase another small rain forest to sheet the fuselage with.Will crack on as soon as i replace depleeted stocks with some more sheet balsa and glue ect. That will be only a couple of weeks until the first show. Regards and soft landing Dave. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 Hi and apologies for the delay, well a trip to Slec and with a hansom discount another 30 sheets purchased so on with the fuselage sheeting,. First i will instal the retractable landing gear. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 So basic lamination of 3mm ply and each side epoxied to either side main formers. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 Falcon have these made and what a lovely retractable unit it is,secured again to 4 laminations of 3mm ply. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 So all epoxied in place and left overnight to dry. This shows it in its retracted state. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 Internal shot from the top of the fuz, as you can see a small portion of the tank bay removed to accomadate the tyre.It is a big old tyre so this is needed. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 So here we go all sheeting scarf jointed and underside reinforced with masking tape , rubbed down onto cyano,gives a great strong join. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 Should have mentioned the upper deck has been removed, so as it was raining i pinched most of the pegs from our washing line !. Main side sheeting was applied with PVA applied by small brush. Close grain balsa sheet for added strength. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted June 17, 2016 Share Posted June 17, 2016 Looking very good Dave. The retract looks like a nice piece of kit, as does the airframe. What scheme are you doing? Quote Link to comment Share on other sites More sharing options...
daveyboy Posted June 17, 2016 Author Share Posted June 17, 2016 Hi Chris thanks for the comments,i dont know to be honest but i think it will be loud as in bright orange and sky blue sort of a fancy sunburst. Fus will be glassed and profilm on the wings i think.It is suprising how mush glue you use on a large build. Quote Link to comment Share on other sites More sharing options...
Martian Posted June 22, 2016 Share Posted June 22, 2016 Lovely build Davey and that retract is a work of art Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 So sheeting the fuselage top deck,started by glueing four sheets of 3mm balsa sheet together using cyano and securing the join with the previously mentioned method. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 So when dry wet the outside area with a sponge and water, drape over structure,use cling film as a barrier if you wish,i apply an old towel so as the balsa softens the weight of the towel pulls the balsa down over the structure. This is what the end result gives you.(see above ).We now have to offer back up to the fuz and roughly trim oversize.Wet again and i tape the balsa to the structure fairly secure to mould the correct shape. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 Next is to trim one side final and apply, i used 30min epoxy a thin layer between the two surfaces.When dry pull balsa to structure with sellotape, then trim final the opposite side and adhere to structure. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 Same with the sheeting around the mount for the tailplane,pre- bend some balsa, i use a spray can as a template,when dry remove and after making a paper template, transfer the pattern to the balsa and secure with 5-min epoxy to blue foam. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 Sheeted the fin with 2mm balsa and added a soft leading edge ( my addition ).When dry the fuz can be sanded back till most joints are flat. Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 Quote Link to comment Share on other sites More sharing options...
daveyboy Posted July 2, 2016 Author Share Posted July 2, 2016 As you can see finished result is not difficult and taking shape now, turn the fuz over and install the bottom forward floor and start on the retract doors.not included in kit so up to you. Quote Link to comment Share on other sites More sharing options...
