Seagull radial rocket
Thanks for that Ron, you are a champion.
Looking at it with more precision, 138mm is spot on. The 133mm I came up with earlier was a quick, rough measurement and in my frustration assumed the manual must have been 20mm out. So in fact it is 25mm out.
So I will go with 138mm. It also helps to fit the Saito 80 four stroke in that it gives it more clearance from the firewall.
So back to the assembly, cheers Graeme
Seagull have obviously updated both the manual and the plane according to the online manual. The landing gear struts have been modified with a different mounting system in the wing too late for mine, Ron's and probably yours!
The old manual shows I.C. & E.P. 113mm New manual I.C. 125mm E.P. 145mm.Just measured mine (E.P.) 146mm. I set mine so the graphics on the cowl would align with the fuselage. it is quite possible that Seagull have made an error again with the manual!
With the motor set at 146mm my C.G. was too far forward had too cut back into the servo mount plate to move the battery (5S 4000) back by approx 30mm.
  • 1 month later...
  • 4 weeks later...
Nice job you've made of the landing gear 'box' and with that style of 'gear you won't get the ground handling problems the standard kit has! the full size Rocket had a variety of landing gear styles including retracts!
But I'm surprised that yours has come out really nose heavy, mine is powered by a Laser 100 and the flight batteries are located just behind the servo tray, on the fuse floor.
As I said earlier, yours just doesn't look like the same kit as mine, the construction is different, are you sure yours is a Seagull Radial Rocket?
  • 3 weeks later...
Thank you for comment, Ron!
Not - I'm not sure that is Seagull but is more or less Radial.
Can it be Rocket I will let you later.
Seems this aircraft is not so optimized for speed like ex. Sundowner....
Any way I've got it as burth-day gift and prepare for speed.....
I don't care that is w/o docs
Let me continue ...slowly ...to the finish:
So for cowl's clear view:
And finally ...
and the AUW:
...meaning wing loading up to 108-109 g/dm2!
Brrrrrr!
Flying/landing brick!
...as many war bird models!
I calc the geometry and MAC and got the CG of 85-95mm in root.
Just the test fly will tell us more.
Stay safe, happy and lucky!
