Tony Bennett Posted October 31, 2016 Author Share Posted October 31, 2016 naaa. tissues and diluted ronseal. not big enough for brown paper in my mind. tissue will fit round the curves better than brown paper would. as René Descartes said. " i build therefor i am " Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted October 31, 2016 Share Posted October 31, 2016 Ah! I just wondered. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 1, 2016 Author Share Posted November 1, 2016 Today i managed to print out the wing plans and cut the wing cores out from 6mm Depron. a nice big fat wing so it should fly nice and slowly. if i finish it. Quote Link to comment Share on other sites More sharing options...
Plummet Posted November 1, 2016 Share Posted November 1, 2016 Will you complete the amazing realism by having a steward or stewardess carrying a tray up and down the isles? (This could easily be made of use in case you need to adjust the C of G in flight. ) Plummet Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 1, 2016 Author Share Posted November 1, 2016 good idea sir. winch servo with a cable attached to the steward. hmmmmmmm no n no no no. he he he Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 6, 2016 Author Share Posted November 6, 2016 working on the centre section of the wing. i need to design the nacelles next. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 6, 2016 Share Posted November 6, 2016 This is very promising, something a bit special. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 9, 2016 Author Share Posted November 9, 2016 spars made for the outer sections of the wings. I have designed all the ribs in Cad and printed off the templates, so i can cut them all out tomorrow and get building again. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 9, 2016 Share Posted November 9, 2016 You've certainly got your Depron building techniques well sussed! Looking good. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 9, 2016 Author Share Posted November 9, 2016 It is starting to become easier. the building and design method is pretty standardized now. so i can crack on quite quickly. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 10, 2016 Author Share Posted November 10, 2016 Well the underside of the wing is now sheeted. the parts that are still open are where the nacelles will go, once i have designed them that is. Ailerons tomorrow... i hope. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 10, 2016 Share Posted November 10, 2016 Tony, which Depron are using on the wings, standard or aero? Is it 3mm? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 10, 2016 Author Share Posted November 10, 2016 Hello Colin I am using standard white 3mm Depron for the sheeting and 6mm grey Depron for the internals. The white is that little bit stiffer than the grey and does not curve as easily, but it is slightly stronger. thank you for asking Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 18, 2016 Author Share Posted November 18, 2016 Been working on the four nacelles just lately. long slow job, but we are getting there. motors have been ordered, so i will be fitting them as soon as the arrive. need to get back to writing over the weekend, so no building for me. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 18, 2016 Share Posted November 18, 2016 Have you designed the retract layout yet Tony? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 18, 2016 Author Share Posted November 18, 2016 retract goes in the ply bit, legs down the middle and the wheel goes in the end. half the wheel will hang out below the nacelle, just like the full size. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 18, 2016 Share Posted November 18, 2016 Spot on mate. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 19, 2016 Author Share Posted November 19, 2016 wheel wells all sorted. started sheeting the underside of the inner nacelles today. you an see the white depron that covers them in this pic. we plod on. motors should be here next week, then i can crack on with the wings. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 21, 2016 Author Share Posted November 21, 2016 we have motors. hope to fit the retracts tomorrow and start the u/c legs. we plod on. Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 24, 2016 Author Share Posted November 24, 2016 Well today has been spent making cockpit fittings and then fitting the glazing bars. Back to the battery hatch tomorrow, then i can crack on with fitting out the wings. Tony B Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 26, 2016 Author Share Posted November 26, 2016 we plod on slowly. battery hatch cover and engine cowls today. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 27, 2016 Share Posted November 27, 2016 Bearing in mind that this started out as a filler while you waited for bits for the Varsity, it out has turned out as another unique project. Well done Tony, this is really good. Edited By Colin Leighfield on 27/11/2016 00:42:25 Quote Link to comment Share on other sites More sharing options...
reg shaw Posted November 27, 2016 Share Posted November 27, 2016 'Tis indeed a great subject, I doubt you'll see another! Grand job Mister. Ian. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted November 27, 2016 Share Posted November 27, 2016 Really must try this Depron stuff!. Looks really good Tony. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 27, 2016 Author Share Posted November 27, 2016 ta gents. Quote Link to comment Share on other sites More sharing options...
