ARC Posted February 16, 2019 Author Share Posted February 16, 2019 Fly mine on zippy 4s 5000mah 40c. Nice snug fit just bring the tray forward a bit and angle upwards. I'll post a pic later to explain Quote Link to comment Share on other sites More sharing options...
Geoff S Posted February 16, 2019 Share Posted February 16, 2019 If this is the Wot4 ARTF like the one I 'built' last back end described here then I'm not sure if a 5AH 4S will squeeze in without a bit of judicious fettling of the internal former. If the only reason you want to fit the bigger capacity battery is because you already have a stock of them for other models then fair enough but the model itself doesn't need the extra capacity (or the weight at the front). I had 7 8/9 minutes flights with mine yesterday using 4AH 4S packs and ended up with around 40% left (according to the LiPo checker - which is only a rough indication). I have certainly had 10 minute flights without a problem which is more than enough for me - especially when it's a bit chilly Geoff Quote Link to comment Share on other sites More sharing options...
