John Whoriskey Posted July 17, 2008 Share Posted July 17, 2008 i have a choice to make between a gws zero or the mustang!which is better??also power train ideas are welcome Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 17, 2008 Author Share Posted July 17, 2008 also could any one recomend a good edf foamyjet?? i like this one but what batt would i use and recever?? Quote Link to comment Share on other sites More sharing options...
iawnski Posted July 18, 2008 Share Posted July 18, 2008 hi john i had the mustang as a glider /didnt use elec in it, but as a glider i had a lot of fun with her and it flew really well,but i went a bit to far and put her up on a really windy day ?bye bye mustang to the great bin bag in the sky. but had loads of fun with it, Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 18, 2008 Author Share Posted July 18, 2008 yea they look realy good Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted July 18, 2008 Share Posted July 18, 2008 My Zero goes nicely with one of the cheapo bell motors and a 910 2S kokam pack and an 8x4 prop. Draws about 12A (not actually bothered to measure it.)Mike Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 18, 2008 Author Share Posted July 18, 2008 wat kv is your engine??and what amp is your speed controler Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted July 19, 2008 Share Posted July 19, 2008 JohnThe motor is one of the bargain bell motors, bearing the legend Bm2408-21m but had no other gen with it. Bearing in mind that I am getting 7,600 on a 2S pack with a reasonable size prop I would guess (but must stress that it is a guess) that it is in the 1200Kv region. The ESC came as part of the package - again anonymous, but is a 15A unit.HTHMike Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 19, 2008 Author Share Posted July 19, 2008 thanks for the help mike is it a fast flyer on that setup? Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted July 20, 2008 Share Posted July 20, 2008 I wouldn't call it fast - but brisk enough to look reasonably scale. It will loop, etc. from level flight. I would have preferred to use a 3S set-up, but I couldn't fit the Kokam 1250 3S packs in. A clubmate has the Spitfire, into whihc he can fit the older Kokam 1500 3S and he uses a pretty gentle current draw, so has about 20 minutes of flying time. I had looked to the same sort of performance, but the 910 2S give around 10 minutes.BTW - these models are often described as park fliers, but I wouldn't fly then in the average park - too fast for that.HTHMike Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 20, 2008 Author Share Posted July 20, 2008 thanks for the heads up that is the firs place i wos gonna go wit it Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 20, 2008 Share Posted July 20, 2008 John, IMHO, one of the best models and best value, is the latest version of the Phase 3 F16, which comes with a powerful EDF, with brushless motor and ESC already supplied! You just need two micro servos and a 3S (11.1v / 2000mah) lipo battery, your choice of rx and that is it! It flies brilliantly, looks great and is a steal at about £85 typically.I have just got one, my son has one and another 4 of us have one each at our club. We are in the process of forming a combat air patrol. They fly fast or slow, have good endurance, are pretty tough and bags of power.http://www.ripmax.com/item.asp?itemid=A-PH015&selectedtab=010&Category=010 Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 20, 2008 Author Share Posted July 20, 2008 a yess i seen one of these fly but im not sure if i have the skill needed for one Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 20, 2008 Share Posted July 20, 2008 They seem pretty docile unless you want them to me mad. Believe me, I'm no hot dogger! Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 20, 2008 Author Share Posted July 20, 2008 makes two of us then!!what recever do you have in it?? Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 20, 2008 Share Posted July 20, 2008 I have a Spektrum 6100 2.4 jobbie. But the others have a right mixture. At least one JR PCM r, a Schulze DSP PPM rx, a JR standard synth rx and others. Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 20, 2008 Author Share Posted July 20, 2008 humm im on 35 meg will it make a diffrence do ya think?? Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 20, 2008 Share Posted July 20, 2008 Well, possibly. I always found 35mhz and electrics a bit glitchy. But that said the guys I fly with are using a JR synth rx, Schulze rx and a JR PCM rx, all 35mhz, without any trouble. For that matter my son has a JR 35 mhz synth in his Kyosho F16, and that's fine too. Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 21, 2008 Author Share Posted July 21, 2008 then f 16 here i come haha Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 21, 2008 Share Posted July 21, 2008 Oh, and I have a Schulze 835 35mhz in my Air Blaster. Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 21, 2008 Author Share Posted July 21, 2008 sounds good thanks for all the help shaun Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 21, 2008 Share Posted July 21, 2008 John, while I think on, you'll need either a tx that can do mixers for the elevons / tailerons, or an on board mixer as the model doesn't have ailerons. Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 21, 2008 Author Share Posted July 21, 2008 i just got an ff7 this week Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 21, 2008 Share Posted July 21, 2008 Cool, should be straight forward then. Quote Link to comment Share on other sites More sharing options...
John Whoriskey Posted July 22, 2008 Author Share Posted July 22, 2008 yep good times Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 24, 2008 Share Posted July 24, 2008 John, if you haven't already ordered your F16, this looks suspiciously like it at a cheaper pricehttp://www.brchobbies.co.uk/?page=shop&item=762 Quote Link to comment Share on other sites More sharing options...
