scott finnie Posted November 20, 2016 Share Posted November 20, 2016 Hi again...I'm really confused about these flybarless systems! I've ordered an Align 3GX for my CopterX kit.It's meant to have 3 flight modes.What do they do? Also do i still need a Gyro as theres lots of varied information on how well it holds the tail. Should have stuck with flybar though looking for a more scale look now Thanks in advanceScott Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted November 21, 2016 Share Posted November 21, 2016 I had a 3GX for about 3 hours once upon a time..... baffled me too so I got rid and swapped it for a Vbar, easy peasy. I understand once set up they do work very well however. I just couldn't get mine to play. I have a couple of Kbar's as well, really cheap, and I cannot tell the difference to the genuine article. The flight modes let you have 3 setups for the heli you can toggle from the Tx. So you can have the same heli change from smooth and stable to wild and lairy at the flick of a switch. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted November 21, 2016 Share Posted November 21, 2016 My story is the same as Richard Wills 2's. I had three, I think, test hops with my 3GX, all of which ended in crashes, before I ditched the 3GX and got a micro BeastX for my T-Rex 550. BeastX setup is simple so long as you go through every step in sequence, with all the adjustments done and stored in the controller, not in your transmitter. I like it so much I got a second one when I converted my T-Rex 500 to fbl and scale fuselage. Quote Link to comment Share on other sites More sharing options...
