Tim Ballinger Posted February 22, 2017 Author Share Posted February 22, 2017 Cut and bent the u/c to shape today while waiting for glue to dry. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 22, 2017 Share Posted February 22, 2017 That looks very nice work Tim, i've a few dural u/c's so no bending for me. John Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 23, 2017 Author Share Posted February 23, 2017 I only have two existing u/c , one too big and one that is so old, battered and bodged I'd be ashamed to put it on a new model! Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 25, 2017 Author Share Posted February 25, 2017 Finished all the top sheeting and front cowl followed by a lot of sanding. Must clear up the mess soon. That nose looks really long when you think we're the pilot would sit. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 25, 2017 Author Share Posted February 25, 2017 The hatch feels really solid having used 4 sets of magnets. Not decided whether to use a mini latch as well or not yet. Perhaps I'll get used to relying on magnetism if I wait a bit. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 25, 2017 Author Share Posted February 25, 2017 So although I do not yet have the right size prop I wanted to check motor position and prop clearence with the cowl. It's clear but only just so a bit more sanding required on the front. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 25, 2017 Share Posted February 25, 2017 Better a little longer nose than a big lumpa lead, looks like shaping the nose was enjoyable John Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 26, 2017 Share Posted February 26, 2017 This start to look like a very complete fuselage Tim. I have good experiences with hatches only hold by magnets, if - and only if - they magnets are kept well aligned. It looks like your hatch can slide to the side. Would if be an idea to use 2 little balsa lists to lock the hatch in place sidewise? Lucas Edited By Lucas Hofman on 26/02/2017 09:22:30 Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 26, 2017 Author Share Posted February 26, 2017 Thanks Lucas, It is currently restrained sideways only by the cutouts in the hatch end formers that fit over the longerons . I have been debating putting some 'tabs' on the inner side face which is what I think you are suggesting. Certainly going to need some form of pseudo handle like Lyndsy had or it will be nearly impossible to get off. Alternative is use two little latches to keep it straight but that seems to go against the concealed feature of the magnets....but would give something to grab when pulling it off. Tim Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 26, 2017 Share Posted February 26, 2017 The hatch end should be more then enough, if needed reinforced by a 6x3 mm list glued on the bottom. That will not make the hatch opening narrower - our hands are always too big. Forces on the hatch when flying are negligible, so if the magnets are so strong that you do not manage to open the hatch you may cut of the former ends so you can push it sideways until the magnets loose their grip. That is how I take off the Ballerina hatch (which has a dowel in front and magnets back. Lucas Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 27, 2017 Author Share Posted February 27, 2017 Just a battery tray today. Time to move on to the tailplane... Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 27, 2017 Author Share Posted February 27, 2017 Forgot the pics... Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 28, 2017 Share Posted February 28, 2017 Ample space for an ESC beside the battery. What concerns me a little is that there is little opportunity to use the battery for getting the CG right. In the Ballerina and the Tucano I had 20-25cm to move the battery back and forth. Lucas Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 28, 2017 Author Share Posted February 28, 2017 Lucas, Funnily enough I was thinking about that when I made the tray so I dropped it down from f3 to the floor and there is room to slide the battery forward into the front cowl (i.e. Under the engine) . I have a piece of 6m square balsa in place which stops that atm but easy to remove I need to move the battery forward. I started the tailplane last night and my good intentions to laminate the le like you evaporated when I saw all the pre cut 6mm in the wood pack. Just too tempting. Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 28, 2017 Author Share Posted February 28, 2017 Meant F2 of course in comment above. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 28, 2017 Share Posted February 28, 2017 Clever! I will keep that in mind. Lucas Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 3, 2017 Author Share Posted March 3, 2017 Bit further.... Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 4, 2017 Author Share Posted March 4, 2017 And somewhere to stand the fin before it gets covered. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 4, 2017 Share Posted March 4, 2017 Coming on nicely Tim, stringers look good on yours, i've struggled a bit with the notches on mine, i'll have some filing to do on em. John Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 4, 2017 Author Share Posted March 4, 2017 Thank you John but I did of course have the ready cut formers from slec which I have to say were spot on. Tim Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted March 5, 2017 Share Posted March 5, 2017 How will you do the fairing Tim? With the Ballerina I made a dummy elevator and fin bit, glued together on the bench (to get them 90 degrees). These were covered with plastic tape that stayed in place until after covering the fuse. Edited By Lucas Hofman on 05/03/2017 06:54:52 Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 5, 2017 Author Share Posted March 5, 2017 Thanks for the thought Lucas, I was just going to shape it with just a support under the rear but filling in the gaps is a neat way of keeping it all solid and shapely. Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 5, 2017 Author Share Posted March 5, 2017 Lucas, Is the infill between the stringers part of the plan or your idea. It looks quite smart. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 5, 2017 Share Posted March 5, 2017 The Ballerina plan shows infils Tim, courtesy of Peter Miller, copied it of me though Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 5, 2017 Author Share Posted March 5, 2017 thanks John, Think I might add that little feature. Tim Quote Link to comment Share on other sites More sharing options...
