Nightflyer Posted February 16, 2017 Share Posted February 16, 2017 I am not new to the Black Magic. I wanted a vintage model back in 1986 and got one of these kits second hand at my model shop (someone had started building the wings and got bored). I duly built it fitted an OS25FP and had years flying it before I decided to convert it to electric in 1997. At this point the model was largely unchanged other than to accommodate a Speed 600 on gearbox, modify U/C to fit 7 cell sub-c pack and she flew. I had a number of very pleasant flights which because of weight were marginal on take off but in the air was pleasant. I decided that winter to strip and overhaul the model put it on a diet but retain the same power set up. The model looked the same but flew so much better, and had several more years until a house move and some bad hangar rash saw the model's demise. Now to the point of this post. I am about to build another Black Magic but aside from being built at the outset for electric I am looking to use a 3S Lipo pack and outrunner brushless set up and wonder what anyone else might have used that works well? Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 16, 2017 Share Posted February 16, 2017 Hi NF, Here's my blog of my leccy Black Magic - motor spec (C3542) is on the first page, although I later reduced the ESC to a 30A. Climbs like a very sedate rocket..... A forum search on 'Black Magic' throws up a number of threads which are worth browsing. Pete Quote Link to comment Share on other sites More sharing options...
Nightflyer Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks for that Pete. Yes there is something about the Black Magic and in electric form looks even better. Quote Link to comment Share on other sites More sharing options...
Nightflyer Posted February 16, 2017 Author Share Posted February 16, 2017 Hi again Pete, Your blog was very good I may well end up posting the build of mine. What size prop have you used and what kind of flight time with the 2200's, I am guessing in the order of 8 minutes? I am looking to hit about 10 or 12 minutes which is what I was able to achieve with my old model but I expect a more lively take off and climb performance with brushless. The geared 600 used to fly around nicely on about 2/3 throttle. Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 17, 2017 Share Posted February 17, 2017 Always good to see build blogs here so please do! I'm unavoidably detained about 500 miles north of my BM at present but I would expect it to be something in the region of a 10x6 or 11x5, IIRC. 8 mins is easily achievable on the 2200 as much of my flight is climb-and-glide, or on tickover throttle to maintain height. With it being a floater, 20 mins airtime isn't difficult to achieve each flight. I made a fairly tedious video a while back, before I changed the motor for one that ran a little more smoothly. I also doubled the ply on the rear of the bulkhead to try and minimise the vibrations which may have contributed to the noise. I suggest you mute the volume on the video....! Pete Quote Link to comment Share on other sites More sharing options...
