Shawbury Tactical Fighter Wing
Righto then. A few of us have decided that these models represent such good value and perform so well, that we will form the STFW. There will initially be about 8 of us, each with a unique colour scheme, but all showing the STFW flash on the tail.
So, here is a quick blog of the asembly process, plus a few minor mods that I'll make as I go along.
Firstly, when you open the box you are greeted by loads of white polystyrene foam, and EDF and tube with brushless motor attached. There's also an ESC, canopy and a huge sticker sheet.
The foam bits are simply epoxied together thus.
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs001.jpg
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs008-2.jpg
I added the supplied reinforcement under the pivot for the all moving tail, but added some thin ply on the top as additional support (on advice)
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs007.jpg
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs005-1.jpg
When I assembled the fin, I added a couple of cocktail sticks too, just for strength.
The canopy comes ready bonded to the hatch cover, but I separated mine, to paint inside and add a pilot. the pilot is a 1/16th scale from Pete's Pilots (eBay)
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs004-1.jpg
Link for pilot
Pilot
The black stuff wwill be removed in time, and the structure painted instead.
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs003-1.jpg
And ultimately this should be the finished product..... ish
http://i94.photobucket.com/albums/l92/winchweight/f-16a_3.jpg
the model is now receiving it's first coat of Tamiya grey primer from aerosol. I have tested it, so fingers crossed the model won't be in a polystyrene pool when I go back to it. I intend airbrushing the other colours on, and will use Tamiya acrylics.
Shaun...why not consider PolyC and ultra light tissue before painting ...or am I too late ?
I tend to use this on all my foamies these days as it really helps to avaid hangar rash with no real weight gain. It could potentially reduce it actually..... as the paint may go further.
Well, haven't done a great deal as the weather brought the family around. But I have managed to get the base colour for the upper surface done (Tamiya Wooden Deck Tan), using post-it notes to mask off the grey lower side. I also added a 3/4 floor to the cockpit, widened the opening and test fitted the pilot.
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs013.jpg
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs014.jpg
Halfway up the tail fin is a moulding dimple that'll have to go in order to get the fin right.
I should also mention, I covered the bearing in the tail section with a blob of blu-tac, both sides, to keep the paint out.
Ok then, as promised I removed the black edging from the canopy and removed the residual glue using white spirits. I then masked it off and primed it in grey, before shooting the base colour. I then added it to the fuselage and airbrushed the second colour on using tamiya acrylics. Ignore the uneven look, it's still drying
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs015.jpg
http://i94.photobucket.com/albums/l92/winchweight/FuryRepairs017.jpg
Once dry, I'll add colour 3, a green-ish colour.
Well.... my mates just blasted aerosols over theirs and it didn't seem to affect performance so I should be fine.
But it is a thought for the future.
Point to note - if you are assembling this kit with a view to customising the paintwork, then there is a moulding flash on the port side of the fin that needs to be filled with a lightweight filler. It's about the size of an old 5p.
i have just seen my new vinyls for this model. They look incredible!
The effort your putting into this shaun is definatley paying dividends just hope its life isnt to short cause you can bet ya shirt it'll be exciting. on the subject of paint weight it'd be interesting to find out how much of the weight of the paint simply evaporates as it dries
