Darran Posted April 2, 2017 Share Posted April 2, 2017 hi Given the relatively cheap cost of x8r receivers I have them in all my models (overkill i know). But I have a very sample t34c that I don't have the room for a big receiver, So has anyone experience with using any of the micro receivers that frsky do with a taranis. If so which 4 channel would you recommend with such a little plane. Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 2, 2017 Share Posted April 2, 2017 X4R if your Taranis does not have D8 mode, D4RII if it does have D8 (I like the D4Rs because they draw less current, a major plus if running on a single cell Lipo for DLGs). Quote Link to comment Share on other sites More sharing options...
Darran Posted April 3, 2017 Author Share Posted April 3, 2017 Could I not use something like FrSky XM Plus EU-LBT 16CH Tiny Receiver with SBUS Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 3, 2017 Share Posted April 3, 2017 Have you got some small S-bus servos? If not you need to factor in a decoder. If I need more than 4 channels I like the X6Rs, smaller than the X8R and they don't use the daft little plugs and ultra-light wire of the XM Plus, otherwise I use the X4Rs. What has put me off the XM is that it's designed for multirotors and just comes with a bare ended harness using wire that's too thin for standard servo plug crimpers to cope with. The wire isn't even silicon so it's quite stiff and I just can't bring myself to trust it. Quote Link to comment Share on other sites More sharing options...
