Myron Beaumont Posted August 5, 2008 Share Posted August 5, 2008 Have built up -tapered ailerons on constant chord wing I am making --symmetrical thick section, Being an idiot ( should have realised at planning stage ) hey have effectively come out with a flat bottom surface & 'cos of the taper & being built without compensating for the change ( diminishing width from root to tip -same thickness at the wing TE join ) they've ended up with about 3 to 5 degrees washout at the tips . No bad thing I say OR what ?Aspect ratio is about 5 to 1 for what its worth. Any comments welcome . Its 3-D ish in design Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 5, 2008 Author Share Posted August 5, 2008 Hmmmm 12 views and no answers Quote Link to comment Share on other sites More sharing options...
Mike Johnson Posted August 5, 2008 Share Posted August 5, 2008 Myron As it has given you wash out at the tips, its no bad thing, will inhibit its 3D ability a bit, but fly it and see, at least it is wash out and will only slow the tip stalling tendancies. Mike Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 5, 2008 Author Share Posted August 5, 2008 Thanks Mike ---Thats what I thought. Will let you know what happens when its done Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 6, 2008 Share Posted August 6, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted August 6, 2008 Share Posted August 6, 2008 Don't forget that you now have wash-in in inverted flight. It's an easy mistake to make - I did it once with an O/D C/L stunter, for which it would NOT have been a good idea. Like you, it wasn't until I lifted them from the board, congratulating myself on the weight and work I had saved compared to carving them from 1/2" sheet that the penny droppedMike Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 6, 2008 Author Share Posted August 6, 2008 Tom & Mike Appreciate what you're saying Yes I do have flaperons & am prepared to be a bit wary inverted But it won't be an issue most of the time -I hope! Mike - Glad you've done the same .In actual fact after having made them I turned them upside down/ changed wing/cant remember exactly but opted for the resulting washout (when not inverted) Thanks for comments Am not unduly worried now ! Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted August 7, 2008 Share Posted August 7, 2008 Good on you, MyronMike Quote Link to comment Share on other sites More sharing options...
Mike Johnson Posted August 7, 2008 Share Posted August 7, 2008 Keep us informed.Mike Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 7, 2008 Author Share Posted August 7, 2008 Will do Mike .Could be a week or so Quote Link to comment Share on other sites More sharing options...
