Robert Armstrong 2 Posted August 7, 2017 Share Posted August 7, 2017 Bought a PSS Me262. Built from unknown plan (or possibly own design) by someone now deceased. No information on c0fg. Will 25% of mean aerodynamic chord back from half span position give a safe start point? Advice gratefully received, hopefully. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted August 7, 2017 Share Posted August 7, 2017 Hi Robert - can you give me the length of the fuselage please? I fly a Neil McHardy Me262, and the CofG needs to be a touch more forward than what online calculators suggest. If it's the same length as mine, I will read mine off for you. Quote Link to comment Share on other sites More sharing options...
Robert Armstrong 2 Posted August 8, 2017 Author Share Posted August 8, 2017 Fuselage 105 cm, span 126cm Thanks Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted August 9, 2017 Share Posted August 9, 2017 Hi Robert, that's very close to mine indeed. C of G 70mm back from LE at wing / fuselage intersection. Good luck, and hope to see you at a PSSA event with it Quote Link to comment Share on other sites More sharing options...
Robert Armstrong 2 Posted August 9, 2017 Author Share Posted August 9, 2017 Thanks very much. Hope so. It will get tried at one of the Leek & Moorland sites in the Peak District. Will post result. Thanks again. Quote Link to comment Share on other sites More sharing options...
