Capt Kremen Posted October 5, 2017 Share Posted October 5, 2017 About to commence a Cloud Models PB 'Bullet' build. This has strip ailerons. My impression, rightly or wrongly(?), is that 'tip/outboard' ailerons are more effective, giving crisper and more precise rolls. (Maybe it's just my poor flying!) What thoughts, outboard ailerons, or full span strips as per original and the kit? A supplementary, if I may. If I fit outboard ailerons, thus allowing the inboard portion of the wing to be 'flapped', would it significantly weaken the foam veneered wing in cutting a thin slot for the servo leads? (I would probably infill with a balsa cap in any case). Thanks in anticipation and for any hints 'n tips on the build, (for electric power), appreciated. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 5, 2017 Share Posted October 5, 2017 I would leave them as they should be....in the good old days of the original "bullet" it was a goodin for displaying its tip stall if you stopped it from flying......I had a one that done the best flat spin I've ever seen from a fair height.... ken Anderson...ne...1.... bullet/flat spin dept. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 5, 2017 Share Posted October 5, 2017 Leave as is, the Bullet is a cracking aerobatic model. The designer got it right Martyn Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted October 5, 2017 Share Posted October 5, 2017 Split the aileron to outboard/inboard sections, then mix the inner to be switchable as ailerons or as flaps and as spoilers. Quote Link to comment Share on other sites More sharing options...
