Fred Keegan Posted October 31, 2008 Author Share Posted October 31, 2008 Waiting for the post to arrive with lightweight glass cloth for the wings. I made a pair of mock guns for the front turret, balsa for the shape then clad in plastic card for ease of painting. Postman just arrived I can start to clad the wings. FRED. Quote Link to comment Share on other sites More sharing options...
Klippy Posted October 31, 2008 Share Posted October 31, 2008 I see you've got the thrust line parallel to the centre line of the aircraft, all the 3 views show the thrust line at 90degrees to the leading edge,is this going to make a difference?Looks wonderful though. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted October 31, 2008 Author Share Posted October 31, 2008 Hi Tony, it's built to the plan and CNC cut parts and the prototype has flown, but on my three view dawings it shows the engines 90 degrees to the leading edge. Quote Link to comment Share on other sites More sharing options...
Klippy Posted October 31, 2008 Share Posted October 31, 2008 Being anal retentive in terms of scale I thought I should 'ring the bell' As an aside, did you know that the outboard floats were mounted on shock absorbers with about 6" of movement for rough see landings?Am I right in thinking that the Flap cutouts on the upper surface are tapered? My MkIII drawing shows them parallel and tapered on the underside.Keep building! I love your attention to detail. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted October 31, 2008 Author Share Posted October 31, 2008 No flaps on my model, I am building it as per Tony Nijhuis design and plans. fred. Quote Link to comment Share on other sites More sharing options...
Klippy Posted November 1, 2008 Share Posted November 1, 2008 Have discovered,I think, that the out-thrust was to give airflow over the tail feathers for better control during docking procedures. The tradeoff was a slight reduction in forward efficiency. Sorry to hear that Tony didn't attempt the flaps, I'm finding it very difficult to find info about them, size (width) and direction of movement, rotational or linear, or I suspect, both. Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted November 1, 2008 Share Posted November 1, 2008 just manage to catch up with the build you are really doing a good job did you get an reply to your question on the ESC from tony ?Martyn Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 1, 2008 Author Share Posted November 1, 2008 Yes he always has long wires to the batterys in multi motor models and has had no problems. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 1, 2008 Author Share Posted November 1, 2008 http://members.tele2.nl/jan.hermkens/index_bestanden/Page354.htm try this site Tony. Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted November 1, 2008 Share Posted November 1, 2008 Thanks for the reply Fred just a quick question if you don't mind is there enough room to install 2 of these in the fuselage instead of 4 batteries (looking at a early Christmas present )thanks Martyn Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 1, 2008 Author Share Posted November 1, 2008 Yes lots of room, I am using two batterys, one driving the outer props and one the inners. If one goes down the you still have a motor running on each side of the wing( have to save up for the batterys ) Fred Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted November 1, 2008 Share Posted November 1, 2008 Thanks so much Fred, I will be doing the same thing and yes the battery's are expensive, but i,v been saving over the pass year to purchase and build this model nearly there I hope and i will add lights as well. Martyn Quote Link to comment Share on other sites More sharing options...
Mike P Posted November 2, 2008 Share Posted November 2, 2008 Hello Fred, What did you use for the cross wires on the float struts and what cunning idea did you have in securing them,they look great. Many thanks Mike P. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 2, 2008 Author Share Posted November 2, 2008 I used fine piano wire soldered on the cross. As you can see on the picture the float struts are on a taper, drill two holes in each strut, when you assemble it together it locks the wire in, I just ran a drop of thin cyno in each of the 4 locating holes. The struts are 1/2 inch streamline aluminium tube from K&S. Fred Quote Link to comment Share on other sites More sharing options...
Mike P Posted November 2, 2008 Share Posted November 2, 2008 Thanks for the info Fred. Regards Mike P. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 2, 2008 Author Share Posted November 2, 2008 Wing covered and coated in PolyC, ready for painting. working on guns today not scale just for the look. Fred Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 2, 2008 Author Share Posted November 2, 2008 Using the Airfix kit for the colors and markings. the decals were enlarged by pyramids models. Quote Link to comment Share on other sites More sharing options...
Klippy Posted November 2, 2008 Share Posted November 2, 2008 Thanks for the info about Jan Hermkens, just what I needed. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 2, 2008 Author Share Posted November 2, 2008 Your welcome Tony. Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 2, 2008 Author Share Posted November 2, 2008 Just about ready for paint,. no rush, will have to find somewhere to spray the main white primer coat, then I can hand paint the rest indoors. then out again for a satin varnish to keep the fingermarks off the mat paints. Fred Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 3, 2008 Author Share Posted November 3, 2008 Nice day today I managed to get the white base coat on the wing, then take inside for hand painting with Humbrol. The colours are a bit darker than on the picture Humbrol 102 123. Fred Quote Link to comment Share on other sites More sharing options...
andy watson Posted November 3, 2008 Share Posted November 3, 2008 Hi FredGreat blog, which I have been following with interest. Can I ask how you found the finish with the hand painting (I presume you mean with a brush!I am thinking about my next build, and have been working on the assumption that to get a good camoflage/warbird type finish would require an airbrush- which I can't afford! Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 3, 2008 Author Share Posted November 3, 2008 I would only brush with mat paints, My problem is I have to spray outside. the cheap airbrush is OK the exspencive ones are for the skilled painters. The finish in the mat paint can always be treated to a going over with T-CUT to get a nice finish. I will do the wing when the paint is hardend offf. Fred PS £12 will get you an Airbrush, or look on Ebay. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted November 4, 2008 Share Posted November 4, 2008 Do you have a compressor Fred? Quote Link to comment Share on other sites More sharing options...
Fred Keegan Posted November 4, 2008 Author Share Posted November 4, 2008 Yes but they are very cheap now , thet make them for spraying tan on. have a look on ebay and in the second hand shops. Quote Link to comment Share on other sites More sharing options...
