Former Member Posted November 3, 2018 Share Posted November 3, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 5, 2018 Share Posted November 5, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted November 5, 2018 Share Posted November 5, 2018 Thanks for sharing this build with us David. I am an avid subscriber now. Truly a masterclass! I particularly enjoyed your sub-thread on wire bending and the use of registration marks. Much better than the 'looks about right' approach that I normally adopt. More please! pete Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 6, 2018 Share Posted November 6, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 6, 2018 Share Posted November 6, 2018 Disc sanders are tremendously useful bits of kit for scratchbuilders. I never realised just how much until I bought one. An adjustable fence doubles it's value, easily. They make cutting accurate ends to your wood very easy. Making square ply formers becomes easy. Making splice joins on strip wood is child's play. Knocking down lumps of block for cowls, piece of cake. Making circular decks, from three thick slabs with 60 deg edges, simple. The list goes on... Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 7, 2018 Share Posted November 7, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 7, 2018 Share Posted November 7, 2018 Those look superb. I thought nice light pneumatic wheels for models were long gone in the face of competition from the moulded foam lightweights. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 7, 2018 Share Posted November 7, 2018 Yeah, but, those Kavan ones look good... I've bought from Conrad electrical before, they sell via Amazon, which is handy if you have accumulated some Amazon vouchers. At the time they were one of the cheapest suppliers I could see for a Spektrum RX. Certainly the cheapest genuine supplier that I could trust on Amazon; they are listed Spektrum agents. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted November 7, 2018 Share Posted November 7, 2018 David, re your half oz. If you make your brass sleeve say 5 mm longer than the axle, drill the brass for a split pin, then you can retain the washers/wheels with the split pin, or a bit of soft wire works as well. Saving most of your half ounce by making the collets redundant. And your wheels don't fall off. Not my idea, I think Flair made it common. Those Kavan wheels look nice. How much? Don't have to answer, but I too will soon have the same need, and my patch surface is really abrasive. Here's a photo of a DVII. Edited By Don Fry on 07/11/2018 12:57:31 Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted November 7, 2018 Share Posted November 7, 2018 I use the same method as Don to fix the wheels on all my vintage models. The only difference is that I fit an 'R' pin instead of a split pin. My wife says I am always 'arpin on....... I'll get my coat. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 7, 2018 Share Posted November 7, 2018 'If you make your brass sleeve say 5 mm longer than the axle, drill the brass for a split pin, then you can retain the washers/wheels with the split pin' Brass tube soldered to the axle on the inside? Or, retained with collet, with screw going through hole in brass tube to clamp on axle? Quote Link to comment Share on other sites More sharing options...
brokenenglish Posted November 7, 2018 Share Posted November 7, 2018 For those looking for vintage wheels. I've used these for the last 30 years: **LINK** Quote Link to comment Share on other sites More sharing options...
Don Fry Posted November 7, 2018 Share Posted November 7, 2018 Nigel, the order of assembly is washer, hole size as axle, followed by brass tube, which holds washer square. And both are soldered to axle. This arrangement acts as an inner stop for the wheel. The hole in the brass tube is distances from the stop washer by the width of the wheel plus thickness of an iner and outer thrust washer. The pin secures the outer thrust washer in place Edited By Don Fry on 07/11/2018 15:19:00 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted November 7, 2018 Share Posted November 7, 2018 The only secret is drill the hole in the brass, and then adjust/shorten the length of the brass tube as desired. It's difficult to precisely put the hole in the correct place after the brass has been cut to correct length. Quote Link to comment Share on other sites More sharing options...
