Craig Spence Posted September 3, 2008 Share Posted September 3, 2008 Hi all,I will soon have my first IC plane and it recomends a 4.8v flat pack battery for the reciever and servos. My problem is I cant decide to go noraml (standard battery pack nimmh etc..) or lipo. I know lipo are brilliant as I use them in my electric planes but im wondering if they come in a size to fit my plane well.I will be buying a 3D Prangster so the pack would have to fit into that. Any advice anyone, suggestion or ideas.Much appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 3, 2008 Share Posted September 3, 2008 A 2s lipo will work but you will have to buy a UBEC regulator to go with it. For a prangster a good 4 cell Nicad or Nimh pack will be fine. Quote Link to comment Share on other sites More sharing options...
Craig Spence Posted September 3, 2008 Author Share Posted September 3, 2008 Hi Frank thanks for the feedback, so Nicad or Nimh would last a while then.What is a UBEC regulator.Cheers. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 3, 2008 Share Posted September 3, 2008 In the old days we use to run the Rx and servos on 600mah 4 cell Nicads and could get a days flying in. Now we worry that a 1500 mah pack won't last long enough. Your average Rx consumes under 200 ma and the servo's only draw power when they operate and unless they are large digitals that will only be a similar amount. I think you would easily get 3 hrs continuous flying out of a 1500 mah pack, but you tend to recharge the pack after every session and I doubt that you will get 3 hours flying in per session.This is a typical UBEC http://alshobbies.com/shop/lookupstock.php?pc=5401&Desc=It's basically a voltage regulator like on a ESC to output a constant 5 or 6v to the Rx from a higher voltage battery. Quote Link to comment Share on other sites More sharing options...
Craig Spence Posted September 3, 2008 Author Share Posted September 3, 2008 Thanks Frank,thats been very helpfull. Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 4, 2008 Share Posted September 4, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Craig Spence Posted September 4, 2008 Author Share Posted September 4, 2008 Hi Eric, cheers for the advice I think ill stick to simple.Cheers. Quote Link to comment Share on other sites More sharing options...
John Sheehy Posted January 3, 2009 Share Posted January 3, 2009 I use a 2s 800 and ubec as receiver batteries in electric and IC planes with no problems. The first 800 came with the Lama 3 helicoptor and I've since bought several more. I don't think it's complicated and I never worry about running out of juice. I have a LiPo volt meter which I've stopped using on receiver LiPo's as they never get anywhere near the low margin. Quote Link to comment Share on other sites More sharing options...
