Spectrum futaba modules
Derek Rawlinson
Hi everyone,
I was reading a forum on an american web site that the futaba 2.4 ghz modules produced by Spectrum are also compatible with the Hitech Optic 6 transmitters.   Has anyone any experience of this?
Apparently, according to a guy on the web site this had been confirmed by Spectrum and their adverts for Futaba modules omitted to mention the Hitech tx by mistake.
 I have a Futaba Faast system and a Hitec Optic 6.   The optic 6 tx is a far better transmitter with more functions and would like to use this on 2.4 GHZ if possible.
Derek
Just when I thought I  was beginning to think I understood  the majority of aspects associated with radio gear etc .
 I too have Optic 6 & futaba 2.4 & would also like to use both on 2.4 .Where am I missing out on what   I thought was impossible & by the way Derek --Which aerial do you use on what  ? Confused
(must be April 1st already)
Hi Myron,
The 2.4 modules were produced by Spektrum just for that reason.  Many people wish to stick with their own transmitters and as far as I am concerned the Optic 6 is one of the best around especially when you consider how much it costs.
I did a lot of research on the web on various forums in the USA and a lot of people their are upset by the fact that Hitec have not yet produced a 2.4 GHZ  system (although they are working on it).
Specktrum make 2.4 modules to fit Futaba transmitters and JR but no mention of Hitec.   In my researches I discovered that Hitec equipment is almost identical, technicaly to Futaba and Mike Mayberry who is the HitecRCD rep in the USA said that it was an oversight on Specktrums part. For the modules to fit, you must of course have a tx with a module!!  The spektrum module replaces your own.
Anyway, the module you require is the SPMMS FUT7 DSM8. This is the module for the futaba systemy you get the module, an 2.4 aerial, and the AR7000 receiver that comes with the DX7 specktrum system.
You remove your Optic 6 module and replace it with the Spektrum one then remove the Optic 6 aerial and replace it with the Spektrum aerial.  You can then bind your AR7000 receiver to the module.
I have tested mine and given it a range check and everything works.   I have not flight tested it yet though.
Everything you need to know is at: www.spektrumrc.com/DSM/Products/airModuleSystems.aspx
Also, check out : www.rcuniverse.com/forum/m_7266310/tm.htm
Hope this helps
Further to my last post above.   These modules cost in the region of £150 and some might say you would be better off buying the DX6i which is cheaper or the DX7 which is about £100 more, but if you are happy with your own TX and wish to continue using it, they are the best bet.
Of course Futaba now make modules for their own gear and they probably also work with Hite.
There is another company which make XPS modules for all transmitters (as long as they have a module already).   There is lots of info on the US forums about this but many people report problems with it.
Hi Chris,
I know what you mean, the Optic 6 is a far better tx with more functions that the Futaba 6EX, which after all is the basic Futaba tx.  Whereas the Optic 6 is nearly the "top of the line" in Hitec systems.
 I should think that a Futaba module would work in an optic 6.   From what I gathered in my research, the Futaba and Hitec systems are very similar techically.   I have never tried it though.
