Glyn Salmon Posted March 18, 2019 Share Posted March 18, 2019 Hi, I have just purchased a Radiolink T8FB, I am unable to connect to a Windows 10 PC. The Windows 10 driver loads OK but when I run the software it only seems to want a COM port. I've Googled but nothing helpful. Doe's anyone know where I am going wrong, please. Thanks for your help Glyn Quote Link to comment Share on other sites More sharing options...
Malcolm Fisher Posted August 21, 2019 Share Posted August 21, 2019 On impulse I treated myself to one of these sets and have similar problems. I don't have a phone which will do the necessary and my PC doesn't seem to want to do the download. Can anyone tell me if the set can be used without being programmed like a none computer radio? As there is no labelled socket for the receiver battery can any of the available unused channels become the battery socket or are the receivers intended for use with electric power via the ESC throttle connection? Help with this would be much appreciated. Malcolm Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 21, 2019 Share Posted August 21, 2019 The outfit comes with a USB cable for upgrades The battery goes to Channel 1, for separate supply, or as you say, any free channel The Tx works as normal without upgrades Edited By Denis Watkins on 21/08/2019 20:36:37 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 21, 2019 Share Posted August 21, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Malcolm Fisher Posted August 22, 2019 Share Posted August 22, 2019 Thank you Denis, I had thought that it would probably be the case but it's good to have it confirmed. I will give it a try with a lightweight model and try to seek help with the download so that I can do any programming. I have a tech savvy grandson who usually sorts out my PC problems. Malcolm Quote Link to comment Share on other sites More sharing options...
