robert mcleod Posted September 22, 2019 Share Posted September 22, 2019 A quick question! Is the XM+ Receiver on EU LBT safe to use with spark Ignition? Thinking to use one as Redundancy to the RX8R Pro Rx. Having lost a model on spark using the X8R Rx, i am cautious. Had no problems with the Pro and D series all good too. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 22, 2019 Share Posted September 22, 2019 There have been many posting about this problem Robert **LINK** Also Search X8R, there is more Quote Link to comment Share on other sites More sharing options...
robert mcleod Posted September 22, 2019 Author Share Posted September 22, 2019 Thanks Dennis, I was aware of the X8R thread and Ignition problems as I did post on it towards the end. The Rx8R Pro Rx I have been using is fine with no interference problems from ignition, wanting to add another Rx for the Redundancy (slave) feature possible, they reccomend using the XM+ and NOT another Rx8R Pro as it won't operate correctly. No use me using spare X8R Rx which I have as I know they fail from experience in a Gas plane. Any tests on XM+ and Ignition engines? You would think if they suggest the XM+ as redundant slave to the Pro that it was safe with Ignition units ....... or would you! Quote Link to comment Share on other sites More sharing options...
flight1 Posted September 22, 2019 Share Posted September 22, 2019 I had used a rx8r and a xm+ ( must bind with out telemetry the xm) had no issues, but have upgraded to rx8r pro and r-xsr throught a redundency bus so i get telemetry through both rx.s Edited By flight1 on 22/09/2019 19:11:16 Edited By flight1 on 22/09/2019 19:35:14 Quote Link to comment Share on other sites More sharing options...
